Question about RCA F32450 32" TV
Zenith A32B43W color problem
The color on the tv is either black and white, sometimes all green, sometimes with a hint of blue.   Haven't done anything to try and fix it.
    Problem Solver:
  • 17 Answers
Classic symptoms! Most of the last TV's made by the old, original Zenith company (Rauland division) had bad picture tubes even when new. This probably had something to do with their going out of business and being taken over by a much better Korean company (LG Electronics AKA Goldstar). Another lovely thing they did before biting the big one was to only sell a complete chassis as a repair part. If your TV is older and has a small white paper tag inside somewhere on the picture tube (usually near the larger brand and type number label) with the code "EIA 1101" on it, discard it. I have NEVER seen one of these work correctly! If the CRT is made by someone else, there may be slight hope. Even if the TV is not very old, if it was really made by Zenith, and not LG, the possibility of repair is slim simply because of the change of ownership. I was sad to see Zenith die such a horrible death. They used to be fairly good, but somehow never made the transition to color TV. After 1954 they were essentially moribund.
Posted on Oct 19, 2007
Why does my KD-32FS170 32" Sony Trinitron screen have blue hues
If you turn all of the color out of the TV, the picture should be black and white. If that picture is not a true black and white picture, the TV will produce a color picture that has that behind it. It takes the proper mixture of red, green and blue light to produce white. This is something that is done inside the glass picture tube.
In your case, one color (blue is stronger) and the others are weaker.
It probably had not been used for a while. SOMETIMES, the weaker colors will get stronger with use. Adjust the brightness and picture controls to get the closest you can to a black and white picture, and then add the amount of color that seems right to you. Use the TV and hope for the best. It will improve, but 2%, 10%, or 50%; I do not know. The proper repair is to replace the glass picture tube, which is not an option at this time. So, turn it on, play games, and HOPE for the best.
Dec 04, 2014 | Sony Televison & Video
My picture is in green. The convergence seems to work just fine. Why would my screen be green?
You might have the yellow for video, white, and red for audio (composite connection) plugged into the component plugs green, blue, red for video, white, and red for audio (component connection) somehow combined together on the back of your TV to whatever source your watching.
It should be color to color from your source to your TV.
It's that or only the green plug is plugged in for the component video. Hope this helps.
Jun 20, 2011 | Zenith R57W46 57" Rear Projection...
I have a Zenith 65 in. TV model #R65W28 serial #271-33220211. The words are blurry and there is a green outline on images in the picture even if i reduce color to black and white. what can i do to fix it?...
It sounds like the convergence drive circuit has gone bad. When that circuit goes the red, blue and green don't line up properly. Have a repair shop check it out. While they are in there have the shop clean the lenses and mirror.
Oct 16, 2009 | Zenith R65W28 65 in. Rear Projection...
My zenith tv picture is bigger then screen
keep the tv ON.then with your remote control pointing it towards the tv press -------- # -------- this button for more then 5 to 10 secods.
to reset.this is if you have orignal remote.
Apr 03, 2009 | Zenith A32B43W 32" TV
Zenith Model SY2551S 1996 27" - Green Tint
The core problem with the green tint is the aging of the picture tube, and can be compensated a bit by using either the green drive control usually located on a printed circuit board on the neck of the picture tube or on the main chassis. There will be 3 main controls which will adjust the red and blue as well. If these controls are not present then you will need to get into the service menu and adjust it from there. Don't adjust anything else as you can make the set much worse. Also remember that in order to make these internal adjustments while watching a black and white picture (turn the color all the way down) you will have your hands and arms near live circuits that could shock you and cause injury to yourself as well as break parts inside the set when you pull back after being zapped (voice of experience here) Of course if you can do all this by the service menu then you won't even have to remove the back of the TV.
Sep 08, 2008 | Zenith C27A24T 27" TV
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Black and White
There some thing that you had done to get black and white on your tv with the dvd ,check your connections.if the connections are properly connected then the tv could be having a problem in the video input, have a tech look at it.
Apr 03, 2007 | Zenith C13A05LG 13" TV
RCA F32450 32" TV Logo
119 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
