Question about HP LaserJet 4700 Printer
Printing from the wrong trey
When I try to load a paper from trey 1 for some reason it would automactically start printing from trey 2. Is this a mechanical or softwear problem, any help would be appreciated.
  • 191 Answers
Hi, your printer tray 1 is not detected by controler, so you need do:
1) change other tray box instead if you have same one, easy fix it
2) check tray 1 box back side, there is a sensor (optical sensor it does not work), you need find out a white lable stick around there, if the lable is not white enough, the optical sensor does not detecting tray 1.
hope help you fix it and answer your question any time, please rating me thanks
Posted on May 14, 2009
My Epson Artisan 7-110 keeps trying to print to cassette 2 (small cassette) even when copying A4. A4 paper is loaded in Cassette 1. Why?
If its not a setting problem, it may not be communicating with your computer properly, try turning it off, wait a little while and turn it back on, if that doesn't work delete your printer off your computer and re install it, Is it the default printer on your computer? some times if you run more than one printer from your computer there's a conflict which can make it behave in weird and wonderful ways.
Sep 22, 2014 | Epson Artisan 710 AllInOne InkJet Printer
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
Error code is 241.07 Paper Jam on display with no actual paper jam.. paper tray is empty but will not feed from next full tray
Amazing. Paper jam error yet there was no paper. Tried to clean it with air, changed paper and restarted. Still no luck! Called Leximark tech support and they asked about the warranty that had just lapsed. Literally the printer was a year and 1 month old. I kept trying to ask if they could just send out one of there techs. After a day and a half someone from Leximark called and said they would need to replace 3 things for ....$909. Mind you they have not even seen the printer. I asked them to explain this ridiculous price, they put me on hold again when finally a guy that didn't seem to care said that is the standard price for us to repair for out of warranty printers. I went to this forum and used a couple of the suggestions. Turns out the arm that raises the paper on tray 1 is slipping. The cogs are not catching when they turn. I was able to assess this by checking the arm on trey 2 which was working well and was not slipping when I manually turned it with my hand.
The fix or the workaround for me was to remove the paper from trey 1 and change the settings to default trey 2 as the main paper source.
I realize this didn't fix it, but I just saved $900 until I decide to get a local repair shop to come and fix the arm on trey 1. I can't imagine that is going to cost $900. This is the last Leximark we will ever purchase.
Mar 31, 2011 | Office Equipment & Supplies
Will not print a test page also unable to find or adjust spool settings and cannot change Priority settings. Some things will print but many items will not, even then it seems very slow.
Printing Problems
? The machine beeps while printing.
The machine may have a paper jam.
• Clear the paper jam (1 p. 13-3).
? Nothing prints.
The power cord may not be plugged in securely.
• Check that the power cord is plugged securely into the machine and into the wall outlet (1 p. 2-9). If the machine is plugged into a power strip, make sure the power strip is plugged in and turned on.
You may not have removed the plastic seal from the cartridge.
• Make sure you install the cartridge properly (1 p. 2-13).
The cartridge may need to be replaced.
• Replace the cartridge (1 p. 12-7).
? Printout does not match the print media size.
The print media may not be loaded correctly.
• Make sure the print media is loaded correctly in the multi-purpose tray (1 p. 5-4).
? Printout is skewed.
• Make sure the paper delivery slots are clear.
? Print media jams occur.
You may not be using the correct paper delivery slot.
• Select the correct paper delivery slot (1 p. 5-7).
? Printout is not clear.
You may not be using the correct print media type.
• Make sure you load print media that meets the requirements for the machine
(1 p. 5-2).
You may be printing on the wrong side of the paper.
• Some papers have a "right" side for printing. If the print quality is not as clear as you would like it to be, try turning the paper over and printing on the other side.
? Printout has vertical white streaks.
Toner may be low or unevenly distributed.
• Redistribute the toner inside the cartridge (1 p. 12-7). If the problem persists, replace the cartridge (1 p. 12-7).
Jan 03, 2011 | Canon FAXPHONE L80 Laser
Printer will not kick out document automatically, attention lite keeps flashing. tray 2 selected but always defaults back to tray 1
Sounds like you have a mismatch in the paper you are trying to print on and the paper that is loaded in the printer. HP printers look to feed paper from tray 1 anytime the computer settings don't match the paper loaded in tray 2. Tray 1 is the multi purpose tray and prety much any size paper can be loaded in tray 1. Double check your document settings and double check the paper size loaded in the paper tray 2 and make sure they match. Also try printing a different document to see if the error persists. If it does this on everything you try to print you should also double check teh rear guide in the paper tray. There is a rear guide in paper tray 2. If it slides back too far it will make the printer think that paper longer than 8 1/2 x 11 is loaded. Push the paper all the way forward in the tray and push the rear guide until it is snug with the tail end of the paper stack.
Nov 01, 2009 | HP LaserJet 4700 Printer
Trouble printing envelopes on kodak esp3 printer
Have you tried this procedure?
Loading Envelopes
You can load plain envelopes into the paper tray of your Kodak ESP 3 All-in-One printer.
Important Do not use envelopes with cutouts or cellophane windows.
1 Remove any other paper from the paper tray.
2 Insert one or more envelopes into the right side of the paper tray with the print side down and
the envelope flaps on the right, pointing left.
3 Squeeze the paper-width guide and move it to its right-most position up against the envelopes.
4 Leave the paper tray open while the envelopes are loaded.
If you have and it's not printing correctly, there is probably a problem with the document you're trying to print.
Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Supply rec. paper Tray:LTR
Sorry i said he reset it, he actually cleaned the feed rollers and run a bypass to allign the feed drive unit, I am getting him back in so i will keep you all posted on the outcome
Feb 21, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Info print 1140
when you go to the menu of the printer is the paper TYPE set correctly?
tray 2 should be letter ( if using plain paper)
tray 3 legal, label etc...
and tray 1 should be any
May 18, 2007 | IBM Infoprint 1140 Laser Printer
HP LaserJet 4700 Printer Logo
193 people viewed this question
Seeker5211
Seeker5211
