Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Refrigerator keeps freezing up. Replaced defraust heater still froze up in about 4 weeks. Tried to replace main board WR55X10037 WITH WR55X10656 BUT THE NEW BOARD DOES NOT KICK MY COMPRESSOR ON. GE SIDE BY SIDE MODEL3 GSS25JFPCC WHEN I PUT THE OTHER BOARD BACK IN IT WORKS FINE UNTIL IT FREEZES UP AGAIN IN ABOUT 4 WEEKS.
    Sergeant:
    Champion:
  • 214 Answers
Please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
Posted on May 14, 2009
  • 423 Answers
I had this problem on a Whirlpool fridge/freezer and solved the problem by replacing the temp sensor that lives inside the freezer near the coils. Here is the part you need (complete with picture)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5201204
Coil freezes
perhaps the drain is plugged in the freezer.
Have you checked this, please let me know what you find and we can go from there to figure this out.
May 12, 2008 | Hotpoint HSS25GFP Side by Side...
Refigerator and freezer all of the sudden don't seem to keep cold enough
The back wall of your freezer covered with snow? If it is I would suggest you replace the heater and a thermistor - Heater: WR51X10101 Thermistor: WR55X10025. If no snow then it is probably the main pcb: WR55X10656
Mar 24, 2013 | GE GSH22JFT Side by Side Refrigerator
GE refrigerator won't keep cool
check the voltage going into you fan w/ the old main board and also w/ the new board. You might be getting a low voltage w/ your new board or the fan you replaced is for a diferent voltage. Have you tried to put the old fan back w/ the new board??
Dec 10, 2009 | Hotpoint HSS25GFP Side by Side...
Gsl25jfpa bs fridge is warm on top and frozen on bottom and freezer is warm
It sounds like the fan in the freezer is not working , to circulate air , and the coldness is just dropping . This will cause the icemaker to stop working first , then the top portion of the refrig next . As this coldness drops , the lower portion of the fridge ( crispers ) , will freeze . The main control board , causes the fan , not to run . Part Number WR55X10656 . The main control board , is located , behind the refrig , behind an 8 " X 10 " , small panel . There is usually a burnt resistor on the board , which is connected to the fan . Unfortunantly , the whole board will need to be replaced . It is easily replaceable . Doesn't take any special knowledge . All the plugs 6 or 7 , each fit the pin plug designed for it .
Oct 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ge pss25mgnaww the refrigerator does not cool or freeze
You have a main control board problem . Pt # WR55X10656 . You can replace the board , or , remove the board , and on the backside , you can visibly see where a solder joint has become "unsoldered" . Resolder this one spot and reinstall the board . The board is located on the back of the fridge , behind an 8 X 10 panel . Be sure to disconnect power before attempting this .
Aug 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is freezing OK. Refrigerator is not
I can tell you that if your model number PSS26MSRSS does not have a defrost timer. The most likely reason for freezing over of the evaporator coils will cause your fresh food section to appear warmer first are the defrost heater and thermostat. Defrost thermostat part number 332b542.jpg WR50X10068
WR51X10042 Defrost Heater
0872122.jpg or the Main Control board is defective. Part number
Click here to see or find these parts or email me at
appliancepartsoutheast@live.com
WR55X10656 Mother Control Board
I hva many solutions and welcome you to offer your Q&A to me, Thanks Sea Breeze
SITE 1=>
http://servicepartstec.blogspot.com/
SITE 2=> http://appliancepartsse.blogspot.com/
Mother Control Board is part number WR55X10656 We need to Check it for burn marks, on both sides. And this is what we need to look for.
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Aug 05, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Fridge keeps freezing
Chances are, they replaced the wrong parts, or didn't replace all the parts, assuming they replaced an electric motor kit. I would need to know the P/N of the electric motor kit to confirm what was replaced.
Based on the fact that it froze the drinking water tank, and if they replaced the electric motor kit, the problem is more likely the temperature sensor or the control board.
Let me know what the P/N is of what they replaced and we can be more precise.
Jan 01, 2009 | Jenn-Air JCD2295HES Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
204 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
