If you have one of the rotary-type, non- adjustable carbs, you may have to install a diaghram kit or rebuild kit as the fuel pump diaghram may need replacing.....otherwise....you may only need to "tweak" the H-speed adjustment screw on this carb. If so, here is how Zama says to do it:
http://www.zamacarb.com/tipspage.html
The tool used to adjust these carbs can be found on Ebay and is less than $10 if you don't rig one by your own methods.
Here is an application list from Zama so you may know what diaghram and/or rebuild kit to install.
http://www.zamacarb.com/pdfs/APPL_CR2010.pdf
Here is a cross reference to the carb's kits:
http://www.zamacarb.com/pdfs/QuickKit_CR2010.pdf
RB is complete rebuild kit and GND is gasket and diaghram kit.
