Question about Hitachi 61SDX01B 61" Rear Projection Television
I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
I have a
I have a Hitachi 61SDX01B (UltraVision/Ultrascan) TV that is about six years old. The following is a summary of the problem and what I have do to date:
Symptoms: At the top of the screen, there are lime/green horizontal wavy lines that continuously appear. Regardless of the mode (TV, VCR, DVD) these wavy lime green lines are visible. At the bottom of the screen there is a smaller amount but the same condition. The wavy lines at the top are always lime green, while at the screen bottom, the wavy lines seem to vary in color as the picture changes. A bit of visual distortion (not with the picture) but rather with the channel header word & number that are in green (ex. channel 2, 4, 7, 56) It has a wrapping effect, like green text and channel number are being pulled towards the back of the TV from inside.
Actions: I took off the big black top back cover (it houses the mirror) to inspect the inside. In inspecting (rt to lt) the red, green and blue projectors I saw not comestic issues. The lens did not seem excessively dusty but I did gently, gently vacuum to remove light dust and spider webs from inside the entire area (not alot). Next, I removed the green proejctor lens and I could see the above symptoms only in the green projector which was the only one with a TV picture visible.
I then replaced the big black cover and remove the lower bottom fiberboard cover (it has numerous holes in it). I immediately gently, genlty vacuumed the dust and spiderwebs off the circuit board and surrounding area. I was careful not to touch or bent anything. Needless to say, nothing improved the symptoms. The only other thing I found was that by putting a small piece of white paper of the green project lens (this while I still have the lower fiberboard off), the TV picture had a strong red hue, but the symptoms were gone. Except for the strong red hue and not being able to see any green colors (ex. can't see the channel text/number) the picture was fine.
Questions: What is causing this symptom with the green projector? What should I expect to pay a repairman? Is the repair worth it?
Thanks In Advance sirericbell@comcast.net
Questions: What is causing this symptom with the green projector? Is it something that a novice/avg. joe can fix? What should I expect to pay a repairman? Is the repair worth it?
  • Anonymous Jan 25, 2009
    I've got the same problem, but with a bunch of blue wave lines. Did you find a way to fix it? Please let me know. Thanks for your time.
    -Bob
    rap21972@yahoo.com
  • Hitachi Master
  • 3,459 Answers
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Posted on Jan 29, 2009
Sounds like convergence regulators are bad...best left to a tech
Posted on Jan 27, 2009
2 Suggested Answers
  • 1694 Answers
SOURCE: Hitachi 61SDX01B
The problem is called green geometry.There is nothing wrong w/the green pix tube.It is critical to get the green geometry
accurate because the red and blue convergence overlays on
the green.If you have more than an alignment issue,that will need
repair before adjustments are attempted.
Posted on Oct 15, 2007
My 61" Hitachi UltraVision has
hello my name is rico, you have bad convergence problem. you need to replace the stks inside the tv, and look for colder on the boards. you gonna need a gun solder, solder, chawick, 2 stks(look in the tv for the number loooks like stk392-120 o something like it) look for bad fuses. that should fix your problem. if you need more help let me know at 602-810-7149.
Jan 07, 2011 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi UltraScan HD Projection Screen 43FDX01B
The convergence board is on the fritz! See TVRepairKits.com and see if they have a kit just right for you!
Jan 12, 2010 | Hitachi 43FDX01B TV
Hitachi 60" Ultravision TV - bad green tube that is leaking
If this has only started to leak recently, get an estimate from a local servicer for a coolant replacement for that tube. The coolant is corrosive and needs to be cleanedup ASAP from any circuit board that it has touched before there is damage. This is NOT a DIY repair. Expect a repair cost in the $300 range for parts and labor. If the set had a good picture prior to this, it may be worth the repair. This is your call. Do not delay however, as any delay will increase the likelyhood that there will be more damage that needs repair.
Dan
Dec 09, 2009 | Hitachi Televison & Video
Rear projection HD Hitachi Ultravision always has greenish tint
This is what you're going to do, Turn on the Tv and go to the service manual, if the green tint is still there, you have a defective dmd board, but if it's no there, then you have an issue with your video board
Jul 09, 2009 | Hitachi Televison & Video
50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
Apr 15, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Remove screen from Hitachi Ultravision
underneath screen remove screws holding screen in place ,it should then slide upward and off.
Dec 08, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi ultrascan HD pic looks like a 3D movie w/o the glasses
Take a look a the video below to determine if you have a true convergence problem or if you can make the adjustment through the menu feature on your TVs original remote.
Apr 03, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Cleaning tv screen
need to know how to clean a hitachi rear projection screen tv
Mar 05, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX01B
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
676 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
