Question about GE Spacemaker JVM1640SJ Microwave Oven
The fan runs when I open the microwave door :GE XL1800 microwave
GE model #JVM1850WD001 ,Spacemaker XL1800 microwave.
problem:Fan runs when door is opened and shuts off when door
closes.
  • dArch1 May 19, 2009
    I ordered a new door switch and will replace
    it. Hopefully this will solve the problem of the
    fan running when I open the microwave door.
    Novelist:
  • 130 Answers
This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common. Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
its not at all fault of your fan its the faulty door switch that has to be replaced.
click this link to check out how door switch looks
http://www.applianceaid.com/image/burnt-switch.JPG
for more help click this link
http://www.applianceaid.com/micro2.html
to replace the door switch manually please click this link
http://www.applianceaid.com/micro8.html
you can order new door switch at
www.repairclinic.com
please do rate the solution.thank you for using fixya.keep updated.thanks.
Posted on May 14, 2009
My ge spacemaker xl1800 light and fan turn on when door is opened. small piece of foil does not spark during this. is there an easy fix?
Kent, most microwaves will turn on the light when you open the door. As for the fan coming on, does it do that all of the time or only after you have used it for a period of time? If it does only after you have used it, you might want to check the back and the underneath of your microwave to see where the fan draws air into the unit and clean any lint built up on the vent holes. Hope this helps!
Feb 09, 2015 | GE JVM3670SK Profile Spacemaker XL1800...
GE Profile XL1800 light out and fan starts running when door is closed
It is not the fault with the fan but the trigger to the fan is shorted. It can be the DOOR SWITCH or the Transistor switch from the board. A fault or error on the processor cannot be ruled out. Clean the main board and reset.
Jan 31, 2013 | GE XL1800 1100 Watts Microwave Oven
My ge xl1800 has 50 volts at the fan when the fan switch is off. it hums because of the low voltage. it works fine when the fan switch is turned on. the fan cap checks out fine
If you have had trouble with the cooktop lights recently, or if you get a hum or buzz in the area of the control panel assembly when you open the door, either indicates that you need circuit board repair. More details here.
Jan 30, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 microwave suddenly didn't work. All buttons on the front panel except "Clock" don't work. Open the machine, shorten the thermostat, the vent fan runs automatically....
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ==-
Sep 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker xl1800 - Funny noise, flickering light
very possible your magnatron is faulty. Disconnect 2 transformer wires and make sure they dont short. try the program again. if no noise, replace magnatron:capacitor and HV diode Please i strongly suggest an electrician help you as it is truely dangerous in there. .
Sep 15, 2009 | Microwave Ovens
A simple test is to place a piece of bread in the microwave ( it heats up very fast) and then if your microwave was actually ON and generating RF, the bread would get hot very fast.. If it remains cool then only the fan is on. It appears that you may have a faulty door switch thou because once you open the door, your microwave should be off..
Are you sure the VENT is not on? That blower will operate regardless of the door open or closed so you must switch it OFF.
Sep 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No heat in GE XL1800 1100 Watts microwave
model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
Jun 21, 2008 | GE XL1800 1100 Watts Microwave Oven
GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Dec 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
206 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
