Question about Ricoh Aficio 1022 All-In-One Laser Printer
Sc543 on ricoh 1022 - Ricoh Aficio 1022 All-In-One Laser Printer
SOURCE:
SOURCE: ricoh 1022 as network printer?
fdsdfas
Posted on Oct 15, 2008
  • 58 Answers
SOURCE: code error sc543 ricoh aficio
SC-543
Heating roller fusing lamp overheat
The detected fusing temperature stays at 200 °C or more for five seconds.
Replacetment the PSU. Got it here: http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 13, 2009
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
SOURCE: SC543 ricoh Aficio 1027
• Fusing thermistor defective or out of position
• Fusing lamp open
• Fusing thermostat open
• Poor connection of the fusing unit
Inspect all the elements before mentioned, soon presses total clear (Yellow Key) 1 0 7 and Maintain pressed clear stop key (orange key) more tan 3 sec. Enter SP 5-810 (SC code reset),
select execute, select close. Exit SP mode, turn the main power
switch off then on.
If the problem continuous the problem can be in the Power supply board, can be defective.
Posted on Sep 02, 2009
  • 197 Answers
SOURCE: Ricoh 1022 service sc544
This is a code for the fuser, which indicates a very serious overheating condition. Your machine has something _seriously_ wrong with it, and should be looked at by a service technician.
SC544 - Fusing overheat error 2
A fusing temperature of over 251°C is detected by the fusing temperature monitor circuit in the SBCU board.
Potential Causes:
• Power supply board defective
• SBCU board defective
Posted on Nov 12, 2009
What to do with error sc543?
fuser error will need to fix fuser first then reset code
Oct 08, 2014 | Ricoh Aficio SP C231SF SPC231SF SP C232SF...
Error sc543
replace the thermistor and thermostatic some time maye be power supply
Aug 08, 2013 | Ricoh Aficio 1018D All-In-One Laser...
Error sc543 sp c320dn
SC542, SC543, SC544, SC546,
These codes are related to fuser temperature. Make sure that power source voltage are not low. check thermisters, fusing lamps etc. To reset this code press "All clear" yellow key, enter 107 and press the red key for some seconds. Sevice mode will be displayed, enter SP 5-810 (SC code reset) and select "1". Then hold down the Photo mode key and the # key at the same time for at least 3 seconds
Feb 17, 2012 | Ricoh SP C320DN AllInOne Laser Printer
Tengo na Impresora Ricoh Aficio 250 y me aparece en pantalla (PROBLEMA SC543) y no me Copias Sacar vu. les agradeceria me ayuudaran Con Este Problema
SC543 is caused by a defective Fusing thermistor. check or replace both center and end thermistor this will solve your problem
Nov 25, 2010 | Ricoh Aficio 250 Copier
Please give me instructions on how to operate a Ricoh Alicio 1022 photocopier and how to take care of it.
What you need is a user guide for Ricoh Alicio 1022 printer. Here is the user guide.
Ricoh Alicio 1022 User Guide
You must have an adobe acrobat reader installed in your system to view this file.
Please rate. Thanks
Oct 04, 2010 | Ricoh Photoconductor CLRType 145 Printer
Hard drive scrub - Ricoh 1022.
Ricoh offers a Data Overwrite Security kit, but I don't think it will work with the 1022. Your best bet is to remove the hard drive, attach it to a computer, and wipe it with a program such as CCleaner or Hard Disk Scrubber (both of which are free to download).
Jun 02, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
The wrench icon is on and code SC543-00 show up in the screen
That code indicates a fuser overheat error or hot roller fusing lamp overheat. Refer to your manual if you have it. Good luck.
Mar 16, 2009 | Ricoh Aficio 355 All-In-One Laser Printer
Ricoh Aficio 1022 All-In-One Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
