Question about Zebra 140XiIII Plus Thermal Label Printer
Zebra printer ribbons
How do you remove the used ribbon so you can install a new one?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Zebra Master
  • 1,362 Answers
Try using this manual for the Datamax ( don't think it should be that much different) Page 28
http://www.posguys.com/download/DataMax-I-ClassManual.pdf
If not then try this one http://service-manual.net/ashop/catalogue.php?exp=&cat=294&shop=1
Posted on Oct 19, 2007
3 Suggested Answers
  • 4 Answers
SOURCE: keep getting broken ribbon message on zebra P330i printer
Hello, assuming the supplies are Zebra and there is no discernible damage to the ribbon, it could mean that the ribbon sensor on the printer is broken. if your printer is still under warranty you can ship back to Zebra (Illinois) to get it repaired. The zebra website has info on how to return printers for service. Hope this helps.
Posted on Mar 08, 2010
  • 4 Answers
SOURCE: broken ribbon message for my zebra card printer
It could mean that the ribbon sensor on the printer is broken. Sounds like you need to send back to zebra for repair. This is free if printer is still under warranty. check out zebra's website for info on how to return printers for service.
I replaced the ribbon in my Zebra 105Se printer and now neither of the ribbon spindles will turn. Only the roller on the very bottom of the printer is turning and I do not have labels set up to wrap around...
There is a diagram that shows the correct route to thread the ribbon and media in the upper lid. All zebra ribbons come off the supply hub clockwise (left to right) and the ribbon only goes under one roller prior to the print head.
Jul 26, 2011 | Zebra 105Se Thermal Printer
I want to change the printer ribbon on Zebra s600 203 dpi, is there a way it will rewind existing ribbon off?
Thermal printers don't use ribbons or ink. They transfer images/text with heat on to special thermal paper.
Mar 23, 2011 | Zebra Stripe S600 Thermal Label Printer
I have a Zebra 105 SL, I have the ribbon installed but the printer tells me that the ribbon is out. I've tried changing the ribbon and labels out but as soon as I power it back up and try printing again...
Calibrate the printer from the setup menu.
You'll (1) Load the label backing with the ribbon (2) remove the ribbon - just shove it to the right, out of the way of the ribbon sensor (3) reload the label and ribbon.
The printer will run a number of labels out.
Feb 16, 2011 | Zebra 105SL Thermal Label Printer
Zebra 105SL thermal Label Printer prints blank with new supplies
Some possible reasons:
1. The darkness is not set high enough for the paper/ribbon combination
2. The ribbon is on backwards. Zebra uses coated-side out ribbons so the ribbon should be coming off the right side of the roll if you're looking at it from the side.
Hope that helps !
Apr 16, 2010 | Zebra 105SL Thermal Label Printer
Warning Ribbon in
If you're trying to print using Direct Thermal and you have a ribbon installed, the sensor will set off that alarm.
If you WANT to print using direct thermal, remove the ribbon.
If you want to print using ribbons change the Print Method in your front panel setup to THERMAL TRANSFER.
Mar 01, 2010 | Zebra S4M Thermal Label Printer
Hello, We have a printer card Zebra p120i
either your ribbon sensor is not working or somehow you skipped it when you threaded the new ribbon.
Nov 26, 2017 | Zebra P120i Thermal Card Printer
Keep getting broken ribbon message on zebra P330i printer
Oct 15, 2009 | Zebra Eltron P330i Card Printer
Hi, my printer is printing blanks. Windows XP, Zebra ribbon I replaced the ribbon and still no luck. I tried setting the darkness to maximum, but that didn't work either. I tried the "dump"...
The zebra ribbon has ink on one side and the other side has a backcoating which protects the printhead. simple way to check is to peel off a label and momentarily stick to ribbon and remove. This will show you which side is inked.
If ribbon is installed correctly then reset the printer and re-calibrate it. 1. install labels and ribbon 2. power on printer. If you have a solid green light on then 3 turn printer off. 4 hold down feed key 5 power printer on and after 2 seconds release feed key. printer will perform a calibration routine and eventually print out status page. IMPORTANT 6 Hit Feed Key once more. Printer will display Out Of Dump message. Your printer has now been sucessfully calibrated.
May 06, 2009 | Zebra LP 2844 Thermal Printer
Ribbon and media sticking together bypassing cutter
Make sure that the ribbon options are turned on the printer. If you recently switch from using thermal stock which doesn't require a ribbon, then it needs to be turned on in the control panel of the printer.
If it is on, remove the ribbon cartridge from the unit and manually turn the wheels to make sure it is moving freely.
Nov 20, 2008 | Zebra 105SL Thermal Label Printer
Broken ribbon message for my zebra card printer
Sep 11, 2008 | Zebra Eltron P330i Card Printer
Zebra 140XiIII Plus Thermal Label Printer Logo
152 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
