Question about GE 24 in. GSD2000Z Built-in Dishwasher
The diswasher arm does not rotate or spray water
When i turn the dishwasher on I can see water shoot out the middle hole. The arm does not rotate nor does water attempt to come out of the wholes in the Arm
  • 1,543 Answers
Check the small holes on the spray arm. They are most likely plugged. (candy wrappers, tooth picks, popcorn or watermelon seeds, you name it.) Sometimes you can clear the holes out, other times it is just as easy (and not very expensive) to replace the spray arm(s). List your model number if you need part numbers or instructions on removing spray arm.
Posted on May 14, 2009
Indesit di620 dishwasher not spraying water from arms
Hi, you may want to try looking at all the holes in the spray arms. If you see anything blocking a hole, use the tweezers and remove the stuff.
Remove the bottom spray arm and check for items in the water delivery hole.Check the lower spray tower that is connected to the bottom rack. Make sure all rotating parts rotate properly. Look underneath to make sure nothing is stuck in the tower. Remove any stuff stuck that is preventing rotation or clogging the tower.
Jun 26, 2011 | Dishwashers
Top sprayer not working
Check and clean the filter inside at the bottom of the dishwasher. Make sure the spray arm rotates freely and that the holes are not clogged. If the dishwasher has a collapsable tower to shoot water into the upper spray arm, make sure it is not stuck and that nothing is blocking it from rising.
Sep 21, 2009 | Dishwashers
Top spray arm does not rotate, is mechanically
try checking the water holes in the arm, as when they spray out the arm turns. If they are blocked in any way it does not turn, try using a needle to check they are clear.
Aug 07, 2009 | Electrolux Kenmore 24 in. Built-In...
Spray Arms won't rotate
good day,
hope this link below will solve your problem.
kitchen appliances
Jul 16, 2009 | KitchenAid Architect? II U SERIES KUDS03ST...
Neff dishwasher
if the arm is rotating freely when you give it a push by hand, then the problem is blockage in the jets in the arm - the arm only rotates with water coming out of angled jets at the end. take arm out, spray water in centre hole and whatever is blocking the jets should become visible. prize out with a paperclip or similiar
Aug 07, 2008 | Dishwashers
Diswasher
Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
Jun 19, 2008 | KitchenAid KUDS01FKSS Dishwasher
Lower arm won't spin
the arm only rotates with water shooting out of the angled jets at the end of the arm and these are probably blocked ( i assume it is free to totate manually) take the arm out and run water into the centre hole and this will help push whatever is blocking it to a visible position - usually rice or sweetcorn. you say there are no obstructions in arm but when no water flowing, the blockage tends to slump back into the main body of the arm and out of sight
May 20, 2007 | Maytag 24 in. MDBS661A Built-in Dishwasher
I replaced the spray arm seal, but the arm still wont spin. I get water but not enough pressure to turn the top arm. The bottom arm works fine. Should the top arm turn easily when pushed by hand. It...
arms should turn freely. spray arms are only rotated by water spraying out from angled jets at end. check for blockage in spray arms - sweet corn and rice are the worst offenders. take spray arms off and run water in centre hole and see it runs out of all the jets freely
Apr 08, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Figidare dishwasher
Maytag MDB4000AWW dishwasher:
Neither bottom or top arms seem to be rotating during wash cycle and dishs do not come out clean!
Wayne Wheeler
Jan 24, 2007 | Frigidaire 24 in. FDB435RFR Built-in...
GE 24 in. GSD2000Z Built-in Dishwasher Logo
485 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
