Question about Toshiba Equium 7100S PC Desktop
LCD monitor back light won't stay on
Have a 22inch lcd monitor with a kind of failed backlight. shortly after the 12V dc power transformer is plugged in to the monitor there is a gentle hum and the backlights turn on momentarily then go off. I've shown a giane flashlight on the monitor and can see that the lcd is working though blackness.
I "discovered" an alternate transformer with the right plug, but is 18V. thinking the 4V difference probably wouldn't make the monitor worse, I plugged it in for a moment and SHAZAM! the backlights turn on, stay on. I limited the time at higher voltage to a few seconds and quit.
Will it hurt the monitor to run continually at 18V instead of 12V?
And second, which part would you think has likely failed?
  • 696 Answers
Running any device 33% higher voltage for any length of time will likely harm it. However, knowing that that worked you have two possibilities.
1. The 12V AC adapter is dying and simply needs replacement.
2. The FLR inverter(backlight) is dying and giving it some extra juice forced a little more life out of it.
Do your best to track down a propper adapter(with 5%, 11.4V-12.6V), if this works that should be your solution, if not then the FLV is dying and you may need a pro to replace it. Generally about $100 at a shop.
Hope this helps FixYa,
Chris
Posted on May 26, 2009
ViewSonic VE170b 17" LCD Monitor Faulty power
You need to check the fuses on the backlight inverter board, also the logic board may be damaged by the AC voltage.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Dec 02, 2010 | ViewSonic VE170b 17" LCD Monitor
How do I replace the backlight in a flickering LCD montior?
It may be back light but unstable power supply due to bad DC filter caps, that will be the first palce to check, repalcing lamps is not a simple job. See my failed SAMSUNG monitors due to bad caps pictures albums.
Lamps: www.lcdparts.net
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
Nov 06, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Philips LCD 170S Backlight problem.. only turns on 1 second and than the backlight goes off..... which component at the power supply board i can replace it?? thanks
It can be DC filters caps with leaking/bulging tops, or they have high ESR, bad transistors or IC or transformers in the backlight inverter circuits, bad lamps assemblies. Please read below and look at the pictures of bad caps, failed monitors, and troubleshooting guides.
Oct 08, 2010 | Philips 170S6FS 17" LCD Monitor
Philips 170s LCD Backlight turns on only 1 sec and than the backlight off. The indicator lamps still green.... anyone can help me? thanks
Oct 08, 2010 | Philips 170S5FB 17" LCD Monitor
Moniter displays for few seconds then goes blank
Look for bad DC filter caps in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jul 03, 2010 | Acer AL1916W 19" LCD Monitor
Why my monitor blacked out?
Failed DC filter caps, cold solder joints, shorted out transistors in the backlight inverter circuits.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Board: www.lcdrepair.us
Jun 26, 2010 | Dell E176FP 17" LCD Monitor
Samsung LCD monitor DC voltage
The internal DC power supply consists of 2 REGULATED power supply circuits, one is 5VDC (about 1A) for logic circuits, another is 12~18vdc (about 3~4A) for the backlight circuits.
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=SAMSUNG%20&megnev2=943&kategoria=&kat2=all
It may not be practical to build two external power supply, and you have to know the points where to tap into on the PCB.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jun 21, 2010 | Computers & Internet
I have a viewsonic 21 inches, the blue light comes ON then OFF, then OFF, then ON. I can hear a transformer trying to oscillate when turns ON but not sign of life...I replaced a few capacitors, still the...
I usually replace or the caps in the DC side of the power supply (5v for the logic and the 12~18vdc for backlight inverter circuits).
If you hear squealing sounds then it can be that the inverter oscillator circuits may not be running at the correct frequency due to either bad tunning caps or bad inverter transformers. Please provide model number.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jun 10, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
Display or power issues with my 17'' LCD screen (SVA LCD #7500L )
Check the high voltage ballast transistor.. see if one of them is burnt... If none.. it could be overheating when supply with current. The ballast transformer supply high voltage for the backlight inverter..If these were overheating then the supply voltage for your monitor will be unstable.
Check also the backlight inverter (cold cathode light) if it is busted.. the function of this backlight inverter is to give display image on the screen.. If these were busted then what you will be seeing is black on your screen. You can also replace this.
Please rate this solution if this help you. thanks..
May 27, 2010 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Lcd monitor backlight wont stay on it turns on but only for a few seconds
If you decide to DIY, please read below so you will know what to look for:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Apr 19, 2010 | KDS K717s 17" LCD Monitor
Toshiba Equium 7100S PC Desktop Logo
876 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
