Question about Sennheiser PX 100 Consumer Headphones
Replacing headphone connector
I have the PXC 250 headphones and I'm reploacing the connector. It's not stereo. There's 3 wires: red, green and copper. which is left, right and ground and any special conditions when resoldering? thanks, Ray
ramirdiaz@hotmail.com I'm trying to fix a pair of Sennheiser PX 100's. The 1/8in. jack "Broke Off" and i wish to replace it with a jack from a pair of old Skullcandy headphones. I don't want to go and buy a new jack so i solderd the wires from the Sennheisers corresponding to the colors on the Skullcandy Jack (Red-Red, Ground-Ground Blue-Blue) and now the sound quality is "lacking" as an understatement. My thought is that im obviously doing something wrong. If anyone could help, or direct me to someone who can, that would save me a great deal of time.
-Thankyou
  • Anonymous Mar 24, 2014
    which color is for left and right sides of headphones when changing the plug there is a re and green wire
    President:
  • 1,137 Answers
The impedance or resistance of the two different sets of wires might be different. The higher the impedance the less signal. If your cable is long enough you are better off spending the five or so dollars for a new plug. Red is right, green or blue is left and copper is ground.( Usually) Unfortunately not all manufacturers agree. Also what could have happened is a short between the wires that you soldered.Make sure they are physically separated from each other and insulated.
Posted on May 14, 2009
One side of the headphones does not give sound consistently... if I jiggle the connector to the ipod and hold it at a certain angel I can get sound to both headphones, but I'd like to find a real...
Well the good news is, it's not your ipod.. It's the wiring inside of the headphones. I suggest that you either return them for a new pair, or buy a new pair.
May 20, 2011 | Sennheiser PXC 250 Consumer Headphones
My Sennheiser HD 205 suddenly had a problem with its jack. You have to move its top, nearest to the cord, to get a sound on the other ear, probably it was pulled and something went loose. I spliced it open...
The two copper wires on your headphones are independent grounds for each channel. Twist them together and attach them to the ground cable ( black) of the new plug. The colored wires of the headphone correspond to the live wires of each channel, and the plug should have the same colors. Wiring together the grounds will not affect in any way the stereo separation, it is just that each ear needs its own ground. Cheaper headsets just transfer the ground from one ear to the other one through the metal headband.
Oct 06, 2010 | Sennheiser HD 205 Professional Headphones
I need to replace my headphone plug end
See my tip on replacing dodgy cable and plugs on headphones.
May 26, 2010 | Sony MDR-V150 Professional Headphones
Replacement connector for Sennheiser PX 250 doesn't work...
The bare copper conductor wire is the screening/common earth to the two signal wires of green and red. The important connection is the copper wire which goes to the jack plug earth which is the section furthest from the tip. The other two are the left and right signal connections. If you get these the wrong way round you will just have to swap them over. Check if they are the right way round by using the balance control on your amplifier or whatever. Have you checked that the problem is not with the headphone amplifier within your equipment? Don't rely on OK sound from loudspeakers as the headphones may be fed from separate op-amp output chip. Try another pair of cheap and cheerful headphones to make sure.
Oct 03, 2009 | Sennheiser PXC 250 Consumer Headphones
PXC250 headphone cable ripped out from electronics box
here is the schematic showing where the wires go. the thick copper is the copper that goes around the rest of the wires. it is not neat like the other wires, but lots of single strands. if you are missing some wires, cut 3 centimeter or so of the lead, the wires missing are probably broken further up the lead.
Getting the solder to wet these wires are notoriously difficult. For me the flux inside the solderingwire was not helping, so i took a match, burned of the lacquer of the end 5mm of each wire, scraped the soot of with a knife, and put flux from a box onto the wire. Then i got the solder to wet the wire. Do this with all the ends of the loose wires. Then solder them to the green board as instructed on the the schematic (it is the top of the two drawings that you want to use).
Be careful not to overheat the PCB. make the solder wet the fire first, then solder the wire to the PCB (green board)
Aug 15, 2009 | Sennheiser PXC 250 Consumer Headphones
Jack plug broken off
Buy a $4.00 1/8" jack replacement from Radio Shack - part # 274-0869, which has small screw connectors that don't need soldering.
Strip about 1" of the braided insulation at the old jack end, which will expose 4 very small wires: Blue, Green, Red, Copper.
Attach the Green & Copper wires to the tallest pin on the replacement jack.
Attach the Red to the shortest pin, and the Blue to the medium pin.
Remember to slide the jack cover onto the headphone cord before attaching any wires!
This works great, I just did it.
May 14, 2009 | Skull Candy Lowrider Headphones
Tdk mp100 headphone jack
Each of the rubber covered cords running to each ear piece has two fine strand wire bundles inside. The right ear piece has a red colored strand and a copper colored strand. The left ear piece has a green colored strand and a copper colored strand. The wires are coated with an insulation lacquer. The lacquer burns off when you heat the wire for soldering.
Repair item: 3.5 mm stereo headphone jack, shrink tubing
Plan for strain relief:. These headphone wires can't take any tension at all. You need to crimp the black cords to the headphone jack somehow.
Slide strain relief and headphone jack housing over the over the rubber covered headphone cord.
  • You need to plan a way to relieve the pulling stress on the solder joints where the two headphone cords enter your replacement headphone jack.
  • Try shrink tubing if you have it.
  • If you have some thermal shrink tubing, slide a piece over the headphone cord end before stripping the wires.
  • Slide the headphone jack casing over the headphone cord also.
Strip each headphone cord 5/8" using the 18 gage setting of your wire stripper..
Hold each headphone cord in a "third hand" soldering assist tool and tease the green, red and copper bundles apart..I wore a 10x Magnavisor and I used a sewing needle and a bright light.
Twist the copper colored strands from both headphone cords together. They are the common ground wires. The copper colored bundle will attach to the headphone jack ground.
Apply a dab of solder to the end of each of the three bundles of wire. You will see and smell the insulating lacquer as it burns off. Keep most of the wire bundle cool.
Position the two strand headphone cord and the 3.5 mm headphone jack in the third hand soldering stand.
  • Plan where you can crimp the headphone cord. Crimp it when ready.
  • The green == left channel wire goes to the tip of the 3.5mm jack.
  • The red==right channel wire goes to the middle of the 3.5 mm jack
  • The copper colored wires go to the ground of the jack..
  • Measure resistance, 31 ohms per earpiece.
  • Screw the jack cover on and finish the strain relief craftsmanship.
Nov 28, 2008 | TDK MP100 Professional Headphones
Ipod headphone
http://www.ehow.com/how_114206_replace-headphone-plug.html
Jan 16, 2008 | Apple iPod nano
My jack plug lead got yanked and broke the wires inside the electronics unit. There are three screws to undo in order to get inside the electronics, one by the cable entry and two very small cross head scvrews in deep holes halfway along the unit. I cut the jack lead on the outside close to the cable entry and drilled out the hole through the cable guide and then poked the jack cable back through the hole into the electronic unit. I was able to solder the three leads to their respective pads. There are five solder pads next to the cable entry. With the cable entry at the top, the middle pad connects to the green cable, the rightmost pad connects to the red cable and the copper connects to a pad about 1 cm down from the rightmost connector. The technique was to tin the ends of the leads with solder before soldering them to the pads. I used a blob of glue from a glue gun to hold the cable in place inside the electronics unit. My plan B if the soldering was not possible was to take a jack plug and lead from an unused set of earpieces and use that lead in place of the original. It would have been much more difficult to replace the lead from the electronics unit to the headset.
Jan 03, 2008 | Sennheiser PXC 250 Consumer Headphones
Open Questions:
Sennheiser PX 100 Consumer Headphones Logo
1,375 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Vito Vacirca Jr.
Gerhardus Stroebel
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
