Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
Using tab key to move around on a field page on a Mac
I was wondering how you use what is normally the Tab key on a PC for moving to different fields on a field document, but how do you do this on a Mac?
    Problem Solver:
  • 10 Answers
Hello there!
Navigating around fields on a Mac is actually just about identical to how you do it on a PC - the 'Tab' key should work the same as what you are used to.
However, by default, hitting the tab key will go to "Text boxes and lists only", as opposed to "All controls", so this level of tabbing may be what you are looking for!  To enable this, try following these steps:
  1. Click on the blue Apple menu, at the top-left of your display.
  2. Click on "System Preferences" (basically this is the equivalent of the Control Panel on the PC).
  3. Click on the icon for "Keyboard & Mouse" in the System Preferences panel.
  4. Click on the "Keyboard Shortcuts" tab.
  5. In the bottom of this pane, you'll see two radio buttons you can choose from for tab behavior.  It is probably set to "Text boxes and lists only"... try switching it over to "All controls", and see if this suits you better.
Hope this helps... Good luck!
Posted on Oct 16, 2007
Sign in on toshiba moves to start but arrow disappears so it wont work
If the cursor highlight is positioned over the START button (icon) then you can select it by pressing ENTER or SPACE bar, which is the keyboard equivalent of double clicking with the mouse. To move between the fields, press the TAB key (shift TAB to go backwards or to the previously selected field).
However, the question is not clearly stated...
Jun 09, 2014 | Toshiba Satellite A135-S2276 Notebook
Mouse not working
The Tab key moves from field to field and the arrow keys move thru items inside the fields.The enter key executes command in the field. So Tab to user icon or password field type in password if needed and hit enter.
Jan 24, 2014 | Lenovo Keyboard
I have a Symbo LS2208 Scanner with a USB cable. The code is 39 I wan to program Shift + Tab and the tab key into the scaner. Here is the steps of what I want to accomplish. I have a window form...
give me the name of the program you curently use so i can try to see how i can convince it to move to the product code when you first scan.
Nov 28, 2011 | Symbol LS2208 Handheld
Try using an external mouse and see if your cursor moves. If it does that the touch pad is probably faulty and needs to be replaced or serviced.
Oct 29, 2011 | Sylvania G-Netbook
I can't login via telnet on my SRW2008 Instead of the normal sreen (with only User Name/Paswoord) I get this menu and when I give User/Password and press Enter it just toggles between User en Password...
The 'TAB' key on your keyboard should move the cursor from one field to the next. On the 'Edit/Execute' field, press the 'SPACEBAR' key to rotate through all the options within a field, e.g., "yes" or "no", and press the 'ENTER' key to select from one of the options. In the 'ID' or 'PASSWORD' field, press 'ENTER' to move on to the next screen.
Dec 23, 2010 | Linksys SRW2008
I have two HP dv6000 laptops and can't unlock the battery from either one. The tab that you slide to unlock won't move.
I have a few suggestions:
Press down on the battery and then slide the tab.
Try compressed air in and around the tab.
Be gentle and use a flat screwdriver to move the tab - careful not to break the tab or damage your laptop.
Hope these suggestions help.
Dec 26, 2009 | HP iPAQ hw6515 Pocket PC
My icons and tool bars are so big nothing I bring up fits on the screen.....I can make the internet smaller with the mouse wheel, but it shows in a very small space because of the very large tool bars....
Here are some tips to help you move around when you can't see other parts of the screen
Alt + Tab (hold down Alt and press tab) will move you between open windows
Tab will move you from button to button and to the file menu at the top
Shift + tab will move you back, for example if you hit the tab key one too many times
Alt + F4 will close the open window, if no window is selected it will bring up the shutdown computer screen
F5 will refresh a page on the Internet
F11 will switch between Full Screen mode and not full screen mode
So try getting to the "approved" window and then using tab to select it.
Mar 11, 2009 | Gateway GT5056 PC Desktop
Tab key on keyboard will not work for moving across columns excel
You need to go into options, open the transition box and un tick the "transitions navigations key" box... This same problem has been ignoring me... You can also fix the double clicking problem in here too... under "edit"
Feb 02, 2009 | Microsoft EXCEL 2004 for Mac
Need the ability to "tab" from field to field on right of kybd
When you press ENTER to finish working in a cell, Microsoft Excel moves the cursor one cell down by default. However, you can select the direction in which you want the cursor to move.
  1. On the Tools menu, click Options.
  2. On the Edit tab, do one of the following:
    • To change the direction in which the cursor moves, select the Move selection after Enter check box, and then select a direction in the Direction box.
    • To keep the cursor in the current cell, clear the Move selection after Enter check box.
Note When a range or set of ranges is selected, pressing ENTER moves the cursor within the range or set or ranges only.
Jan 22, 2009 | Logitech Marble Mouse Trackball
Moving within page with columns
What program are you using? The answer may be different if you are using a Microsoft product, vs an Apple product, on your Mac.
Have you tried shutting down and restarting your Mac?
Jan 31, 2008 | Apple Power Mac G5 Desktop
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
475 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
