Question about Acer Aspire 5315 Notebook
The mouse on my acer labtop has stopped working
Whenever i move my finger across the touchpad it does nothing. It wont move at all.
  • jrenee22 May 15, 2009
    thanks alot you have really saved me hundreds of dollars!!!
  • Acer Master
  • 13,433 Answers
If you look at the F1 to F12 keys you should see one of them have a finger picture on a touchpad picture on mine its F7 so pressing FN and F7 should turn off and On your touchpad, works on mine.I have a acer aspire 5020sitting next to me here.
Posted on May 14, 2009
  • Ekse May 14, 2009
    if that doesn't solve the problem, and it should solve it.
    touch-pad is not working properly or for some reason is not installed or detected by windows.
    Then you have either faulty touch-pad
    OR faulty touch-pad connector
    OR faulty touch-pad flex cable
    OR faulty touch-pad motherboard connector
    OR faulty motherboard.
    it will need to be tested by a professional since you don't have extra touch-pads laying around or do you?
    Try a usb mouse. you can check if the touch-pad is detected and or working properly in windows by right clicking on my computer select manage and from manage window left side click on device manager then on right side look for the mouse or touch-pad also look for any ! or ? yellow or red warnings.
Acer Laptop Help
To get started with this product, complete the following steps.
Turn the laptop on by pressing the Power button located above the keyboard.
Locate the touchpad.
You use the touchpad much like you would use a mouse.
The touchpad controls your cursor.
It responds as you move your finger across its surface.
Move your finger across the touchpad to move the cursor.
Locate the bar below the touchpad.
This bar may be used for selecting and has left and right-click functions that you can use a mouse.
Clicking on the right end of the bar has the same effect as right-clicking with a mouse.
Clicking on the left end of the bar has the same effect as left-clicking with a mouse.
Tapping the touchpad is the same as clicking the left end of the bar.
Use the keyboard like you would use a desktop keyboard.
The only difference is that the keyboard of an Acer laptop is smaller than a regular laptop keyboard.
Click on the Windows icon in the lower left side of the screen to access programs.
Make sure your wireless switch is turned on, if you want to access the Internet.
Then locate a wireless network.
Windows may automatically detect and display a list of available networks.
If that happens, you only have to select the network you wish to access.
If it is not your network, you may need a password if it is security-enabled.
If Windows does not automatically detect a network, open Internet Explorer, and follow the on-screen instructions to connect to a wireless network.
Acer user guides and manuals
http://safemanuals.com/brand-user-guide-instructions-owner-manual/ACER
May 24, 2013 | Acer Aspire Computers & Internet
Acer mouse disassemble ???
The Acer Aspire is a laptop model that has a built-in "mouse pad," also called a "touchpad." The user runs his or her finger across the mouse panel to move the cursor. If your mouse pad no longer responds to your touch, it may be due to a build-up of dirt and grease. Another common problem is having an outdated or damaged mouse pad driver. These problems can be quickly resolved without having to take apart the laptop.
Hold down the "Fn" key, which is found at the bottom left corner of the keyboard. Press the "F7" key once while holding the "Fn" key. Look for a message that says "touchpad enabled." b> Update the Drivers Go to "Start" > "Control Panel" > "System and Maintenance" > "Device Manager." Double-click on "Mice and other pointing devices" to expand the options. Right-click "Synaptics Touchpad" and then click "Search automatically for updated driver software." Wait for the computer to scan and install new drivers. Restart your laptop.
http://www.youtube.com/watch?v=oUyxhcQk6G4 Acer Aspire 5738 7736 Touchpad Mouse Replacement
Jan 30, 2013 | Acer Computers & Internet
I turned off my touch pad to my acer aspire 5733z and it wont turn bk on
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 16, 2012 | Acer Aspire 5733z-4851
I have a HP pavillion DV6-1250us Windows vista home premium and i cannot get my mouse to scroll up or down? how do i fix this?
To move the pointer, slide your finger across the TouchPad surface in the direction you want the pointer to go. Use the TouchPad buttons like the corresponding buttons on an external mouse. To scroll up and down using the TouchPad vertical scroll zone (right edge of the touchpad), slide your finger up or down over the lines.
NOTE: If you are using the TouchPad to move the pointer, you must lift your finger off the TouchPad
before moving it to the scroll zone.
Mar 03, 2011 | Computers & Internet
My Touchpad wont work
the problem may be with the touchpad drivers.Please update it or reinstall it
Jul 10, 2010 | Acer Aspire One PC Notebook
Mouse moving in opposite direction
you might have to scync the mouse go to labtop settings and it will work or your labtop i messed up
Dec 27, 2009 | Dell Inspiron 1545 Notebook
My acer 5532 touchpad has suddenly stopped working... any ideas? mouse doesnt move and usb wireless mouse doesnt work either.. although it does on myu sister's laptop
Thanks. The Fn F7 idea did not work, the Enable/Disable toggle in Control Panel made no difference BUT the simple pressing of the TINY finger pointing next to the power button DID work. Duh!
Nov 15, 2009 | Acer Computers & Internet
The mouse on my acer labtop has stop working
I get this problem quite frequently myself; there doesn't seem to be anyway around it. just restart your laptop and it should work fine again.
May 14, 2009 | Acer Aspire 5315 Notebook
Mouse tracking problem on my touchpad
1.See if it still same if you try use USB external mouse?
2.maybe you can try this:
swtch off your laptop, use 99% pure isopropyl alcohol to clean the mousepad carefully, DO NOT spray directly onto mousepad, spray to a cleaning cloth and wipe the the mouse pad carefully.
3. Could be virus
Nov 12, 2008 | Acer TravelMate 4100 Notebook
Acer aspire 5620 touchpad problems
Go to acer website and look for support/then driver download/select your model/and download/do RUN instead of SAVE
Aug 24, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5315 Notebook Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
