Question about Tomtom GO 910 GPS Receiver
Does it have reset button not coming on but is charged
Tom tom not coming on but fully charged
You need to use a safety pin to reset the TOM TOM.
The reset button is on the bottom of the unit. It is a very small hole.
Put the pin in there, hold it for a few seconds and that should enable you to turn it back on.
Posted on May 22, 2009
No GPS signal
Ok Marilyn,
Thanks for the info. Your device has no dedicated reset button like some other Tom-Tom units, but it still can be reset.
To perform a reset, make sure that the unit has a fully charged battery. Charge for several hours if unsure - and make sure the charging light comes on (if it doesn't - it will probably need service) while connected.
Disconnect from charger.
Press the On/Off button to turn the unit on (if not already on) and allow it to start up as usual.
Press AND hold the On/Off button for up to 15 seconds or until the unit turns off.
The GPS should now be reset, and should work as expected when you next turn it on. Good luck!
Apr 15, 2012 | GPS
After pressing the on/off button nothing is happening,Ionly have the screen Tom Tom nothing else!
First, check that the battery is properly charged. To charge the battery, connect your device to the car charger. It can take up to 2 hours to fully charge the battery.
If this does not solve the problem, you can reset the device. To do this, press and hold the On/Off button for 15 seconds and release the button when your device begins to restart.
Hope this helps.
Feb 28, 2011 | Tomtom XXL 540TM Portable GPS
My tom tom is over 2years. I am not getting a signal. Asks if I am in a building
Mainly the problem with this tom tom one is that it comes up with this problem frequently. The solution to this problem is for you to reset your tom tom by holding the reset button for a while, after doing that, it will reset it and it will be able to receive signals.
Solution: Reset the tom tom by holding down the reset button for a while, it will reset it and then it will be able to receive signals once again. To reset: check that your battery is properly charged, by plugging it for at least two hours, make sure the charging light is on. Then you press and hold the power on/off button for about 15 seconds, then it will restart the system for you.
Be sure to have your tom tom in a car or in a outside position where it can receive signals from the satellite.
This should do the job.
Dec 22, 2010 | Tomtom ONE GPS Receiver
Tom tom will not turn on, but charge light works.
Please connect your tom tom to the power adapter first.Get a paper clip and press the reset button under the SD card slot of your tom tom.Reset button is a very small small hole at the back near the sd card slot.Keep pressing the reset button for 2mins and also press the power button till the light comes on.
This should fix the issue.Let me know if you need any more help.
Jul 08, 2009 | GPS
Tom tom won't turn off
if it does not proceed when the icon is selected, presume data corruption or in fact no data.
TomTom is renouned for this type of problem.
try rteinstalling the map data from the source.
try a reset first ( small pinhole on rear) put open paperclip end in and gently push the button inside) if this still fails then data installation is the go
Jun 23, 2009 | Tomtom GO 720 GPS Receiver
It won't turn on
I just had the exact problem as you did. On the TomTom website mentions that you can press the Turn-on button for 15 seconds to reset it. I tried that and it worked. Maybe it'll work for you too.
Apr 21, 2009 | Haicom HI-406BT-C GPS Receiver
Tom tom will not switch on
try charging the tom tom fully and then reset while it is charging. a tom tom will not reset unless the new battery is fully charged which may take some time if you only have a car charger.
please give me a fixya! rating if this helped.
Apr 04, 2009 | Tomtom ONE 3rd Edition GPS
My 300 Tom-Tom quit on me. No screen or anything. Help!!
Plug it into your computer using a USB cable and press the reset button. Once it resets, keep it plugged in and your computer turned on, until the battery is fully charged. Every so often, charge it. If the battery goes totally dead, it will create problems.
Mar 19, 2009 | Tomtom GO 300 GPS Receiver
How do I reset to factory settings how to reset factory settings on tom tom one
Which Model of Tom Tom One ?
XL
3rd Edition
2nd Edition
make sure you're fully charged, remove any optional memory cards (depends on the unit) there should be a reset hole, place a straightened paperclip into the hole and press for 15 seconds.
140/130/125
make sure you're fuly charged, press and hold the on/off button for about 15 seconds until the unit restarts
Mar 18, 2009 | Tomtom ONE GPS Receiver
Tomtom GO 910 GPS Receiver Logo
245 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
