Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
AMANA AMERICAN FRIDGE FREEZER REF228DIRB
I just bought a second hand AMANA AMERICAN FRIDGE FREEZER model no: 228DIRB and have been given a MAYTAG plumbing kit. Having read the instruction I'm not sure whether I have been given the correct kit. Does anyone know how to connect the water supply pipe to the back of the fridge.
Regayds
Javid
    Sergeant:
    Champion:
  • 214 Answers
Don't worry! find out a valve in the back of the refrigerator and after that connect the outlet with it. if there is no valve than there would be a hole behind the refrigerator....... just connect the outlet with it.............................have a nice day :-)
Posted on May 14, 2009
Whirlpool 6th sense fridge freezer electronic panel - how do i unlock? child lock not on
Emma:
The lock and unlock feature is accomplished by holding the lock button for 3 seconds, and you will see a count down number just above it that indicates 3, then 2, then 1, and a soft tone along with the lock icon appears. To reverse this hold the same button for 3 seconds following the same procedure and the unlock icon will appear.
Jul 14, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Amana American type Fridge Freezer control board
you can order this from multiple places, I personally would use repair clinic because of the return policy. The part number is W10206104
May 22, 2012 | Refrigerators
Faulty water dispenser on stoves american fridge freezer
There is air in the line. Let water dispense until it quits doing as you described.
Aug 26, 2017 | Refrigerators
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
My freezer side isn't freezing. fridge side seems to be working
If it worked fine to them, look at the heating and cooling C. in the back of the frig. Depending on how you transported it and how many bumbs you hit could of damanged them
Apr 03, 2010 | Amana SXD524VW Side by Side Refrigerator
Plumbing in fridge/freezer
That is the water inlet for the ice maker. It is 1/4 inch diameter and will need to connect to a valve of that size with 1/4 inch plastic or copper tubing.
Please rate if this helps-
Mar 23, 2009 | Whirlpool Home
Instruction manual needed.
You might find it at kitchenmanuals.online That is the web address and they have manuals for many different models of the Amana side-by-side refrigerator.
Jan 25, 2009 | Amana Refrigerators
Compressor very hot + water leaking
This is not normal. The coolant charge is low which means it leaked out some where. Return it.
Dec 22, 2008 | Sub-Zero 650 / O Bottom Freezer...
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
162 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
