What's the trick to ''waking'' this monitor up? I tried powering down and that didn't work.
  • 91 Answers
Make sure that your monitor is connected to your PC. if so, turn off your PC and monitor, and then turn on the PC first, then your monitor, and they both should then come on...
Posted on May 14, 2009
  • AJ Jones
    AJ Jones May 14, 2009
    Thanks for the rank!! :)
Aoc e2043 osd locked.How do I unlock? Lt button trick didn't work.
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. best regards
Aug 25, 2012 | AOC LM742 17" LCD Monitor
I have a hp v75 old desktop computer that I brought from my garage, I got everything plugged up, but the monitor wouldn't show anything.. I googled it and I didn't think it would work but I just...
As your monitor had showed up once before, I assume it is still in a good condition. The next time, you were not able to wake up the monitor by pressing the power button on your CPU cabinet, which means, the power supply to the monitor may have been interrupted. To check whether your monitor is working properly, plug it to any direct connection and see if the power button on the monitor is flashing. If this works, get everything plugged up, check all the connections properly and try to run the computer again.
Hope this helps, Mrityunjay.
Jun 28, 2012 | Computers & Internet
Hello: Just recently, the 2159m HP monitor goes to sleep in the middle of an activity. This happened on two desktops and different settings. Repalced the video card, adjusted settings, replsced DVI...
Check the cord and connections for the monitor; this has one wire that must have voltage on it or the monitor goes to sleep, and a broken wire or loose connection will fool it into thinking you are powering down. If this doesn't work try going into power options and setting monitor to never power down.
Jan 22, 2011 | HP 2159M Monitor
HP Pavillion won't bring monitor back from sleep mode
hi...if u can read " no input signal" from ur screen, this means that ur monitor is ok..
Look if u have power buttons on ur keyboard.. try to wake it from there.. some pc may have shortcut keys to bring back the pc... look @ ur pc docs on the internet for more info...
However if it's a hardware issue, it may be that ur RAM memory needs to be cleaned
Feb 01, 2010 | HP Computers & Internet
Dell SE198WFP 19" LCD won't come out of standby
I went into the BIOS (with F2 during restart) and changed a value -- IIRC it was called something like "power management scheme" -- from the default S3 to the other choice, S1. Now the old Dell XP Dimension 2350 will go into and out of Standby correctly and the new SE198WFP 19" LCD will too.
Oct 05, 2009 | Dell SE198WFP LCD Monitor
Hii iam pankaj i have dell SE178WFP LCD monitor. My problem is whenever i start my pc monitor shows that it is on power save and monitor starts blinking.. what can be the problem and how it can be...
Try holding down the fn and f8 keys or if your problem is you cannot wake from power saving mode (after your PC goes to sleep, then its probably just the driver for your video card). VISTA has some issues with certain drivers that the PC cannot wake from sleep
Jul 30, 2009 | Dell E176FP 17" LCD Monitor
AOC Monitor says "no signal" and won't wake up!
This monitor refuses to wake up because it cannot find the signal from the computer.
When the light is amber, force the pc to shut down by holding the power button until all lights go off. Then, after about 10 seconds, power the pc back up again.
If this does not start your monitor, unplug all the monitors connections and plug them back in again. These things should reform the connection from the pc to the monitor.
good luck
tony
May 18, 2009 | Computers & Internet
Dell monitor enters power save
try to reconnect the cables to ensure it's properly plugged in (if you have another monitor, you can try it to ensure that your system is running properly) If you narrow it down to a monitor problem, it's most likely the inverter/power supply board in the monitor. If it's covered under warranty, you can send it back to Dell and they should send you a refurbed unit. If not, the board can be as expensive as finding a decent used monitor on ebay that works.
May 02, 2009 | Dell E193FP 19" LCD Monitor
Monitor does not wake up.
Check the inverter and backlight bulbs.
Mar 27, 2009 | NEC MultiSync LCD1550VM 15" LCD Monitor
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
