Question about Dishwashers
I have a Maytage Model# MDBH940AWW dishwasher. The lower spray arm does not rotate. I changed out the sealkit, but the results are the same. The top spray arms are turning, but not the lower.
  • lee_andre992 May 14, 2009
    I did notice some black plastic pieces in the lower spray arm that I don't think I can get out. So, you may be suggesting a "new" spray arm which is fine. Might part of he problem be related to the impeller? The upper spray arms work fine, but I was wondering if the impeller (black) had some issues.
    How does the water get inot the lower spray arm? I can't
    Sergeant:
  • 326 Answers
These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
click the links underlined in blue
How to check a dishwasher spray arm.
How to remove and replace a dishwasher spray arm.
Find a dishwasher spray arm.
Goodluck,
Please don't forget to rate or accept the solution
Posted on May 14, 2009
My Indesit dishwashers lower spray arm comes off resulting in flooding do I need new arm support
Yes. The water pressure in the hydraulic system is very important.
If more water flows through the hydraulic circuit of the lower nozzle, then probably that the upper nozzle will not rotate which will cause poor wash results.
Dado
Oct 25, 2015 | Indesit Dishwashers
Why are the items on bottom rack not being cleaned properly
If is clean dishes in the upper basket, I conclude that the pump produces enough pressure what means that the lower spray arm for some reason does not rotate and because that washing result is bad. Before washing I would check the lower spray arm rotates freely and after that open the door during washing and check if the lower spray arm rotates. Sometimes, the holes in the spray arm clog and disable turning which leads to poor washing results in the lower basket.
Dado
Aug 17, 2014 | Indesit Dishwashers
Lower dishwasher arm not rotating
Probably blocked spray arms is the cause of the unit not cleaning properly or rotating. Remove each spray arm (there are 3 in total) and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Jan 25, 2010 | GE Dishwashers
Spray Arms won't rotate
good day,
hope this link below will solve your problem.
kitchen appliances
Jul 16, 2009 | KitchenAid Architect? II U SERIES KUDS03ST...
Dishwasher lower spray arm falls off
These parts can be replaced easily and reasosnably cheaply for example the top spray arm is about £20.00p. But you need the back water feed tube as well as the lower spray arm which should come as one package. (depending on model i'm going by bosch). You shouldn't have to pay more than £30.00p + p&p. Hope this helps.
May 19, 2009 | Dishwashers
Lower spray arm is not rotating
call sears help line thewy have mech that can help
Mar 14, 2009 | Kenmore 15899 Built-in Dishwasher
Upper arm does not spray
Dig deeper, until you find filters. Those are probably clogged. You may need a screwdriver...
Dec 29, 2007 | Kenmore 15952 Dishwasher
DISASTER! PLEASE HELP. WOKE UP THIS MORNING & DISHWASHER MELTED!!!
Amsanta, sounds like something got hung up on the heating element, stopped the lower spray arm and things started to melt. The lower spray arm, part number, 154414101 is easy to change out. There is also a lower spray arm support 154294101, don't know if you will need that. I believe on your model the lower spray arm just snaps on. There is a tab on the filter screen that will rotate to unlock and the filter screen will lift out. Now the lower spray arm support is accessable. If it's less than a year old, you may be able to get it fixed under warranty. Catriver.
Jun 09, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Small plastic top and mid spray arm do not turn, bottom does
decrete, you want to get down to the chopper and screen. If the screen is plugged up with gunk there won't be enough pressure to reach the top spray arms. Check out the posted pics. Remove the lower spray arm. Rotate the rear feed arm to the right until it unsnaps from the tube going up the back. See the 4 torq screws holding the filter on. Remove them. Lift the filter up. Now you will see the chopper inlet cover. 1 torq screw holding it in. Lift it up and there's the chopper and screen. Catriver..post back
Apr 09, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Dishwashers Logo
216 people viewed this question
Top Dishwashers Experts
Owen Barnes
