Question about Kenmore Washing Machines
Loud noise when stoping
Kenmore 90 series has a loud noise when stoping and the washer will move when it stops.
    Sergeant:
    Champion:
  • 214 Answers
Please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
Posted on May 14, 2009
Noise while spinning
My 90 series kenmore washer. At the start of spin,makes loud clicking noise while it spins. Than it stops after a min. I changed the coupler. Still makes noise.
Jan 05, 2014 | Washing Machines
My Kenmore 80 series washer won't spin, and it just makes a loud gear grinding noise. What could this be, and how do I fix, in the simplest form please I'm chick... :)
rebecca it is probably the motor coupler. Move or slide ur machine over and if there is ruber filings under it then it is the coupler.
Apr 04, 2012 | Kenmore 24032\24036 Top Load Washer
Series 90 with loud buzzing/grinding noise, won't spin
It could have gone out of balance. See if the drum looks off center and center it if necessary. Turn it off and back on to reset the switch. If that doesn't work, try pressing on the lid either 2/3 of the way back on the right or all the way back on the left (depends on the model -- try both) and see if it starts. If it does, I would suspect the lid switch.
Jul 21, 2010 | Kenmore Washing Machines
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Kenmore 90 Series Washer Noise--Won't spin
For Tegres
If the noise is only when there is water flowing, check tighten the screws that mount the water fill solenoid valves to the case. The solenoids operate on line current so they vibrate at 60/50Hz (local suppply frequency) if they are loose at all, the noise is loud the body acts as resonators
For SRONEAL, that symptom describes coupling failure exactly, have you removed the coupling to check, often times the motor side hub is stripped, but there is no visible external damage
Jul 23, 2008 | Kenmore 15864/15862 Top Load Washer
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Squire
