Question about GE Profile Harmony DPGT750EC Electric Dryer
Dryer Doe Not Heat
Finally got the cabinet apart & the element has continuity so does the safety shut off sensors. Any Ideas
  • 833 Answers
Have you got both breakers working? Turn them off and then on. Is the timer or relay board doing its thing? What about the thermostat? Follow the diagram on the back of the unit with a multitester. Be aware of the fact that 220 V can kill.
Posted on Dec 18, 2007
SOURCE:
Dryer is spinning but not heating. we cleaned vents, unplugged dryer and replugged in. now it still won't heat and an hourglass symbol has appeared on control panel
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Apr 11, 2015 | Samsung DV419AE Dryer
My kenmore dryer model#110.61202013 wont heat up
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Feb 22, 2015 | Kenmore Dryers
I replaced fuse, high limit thermostat and thermal cut off, still heater does not cycle on and off, just gets hotter and hotter., is this the thermistor or something bigger?
I would first check to see if the heating element is shorted out. When the vent or blower housing of the dryer get built up with a lot of lint the dryer won't vent out the heat properly and it can cause the heating element to warp and short out against the cabinet. To check for a shorted element you should unplug the dryer and remove the bottom panel. On the right side you will see the heating element, remove the two wires that connect to the element. With a multi-meter, check to see if you have continuity from either side of the element to the cabinet that hold the element. You should NOT have continuity when you check for this, if you do the element is shorted out and will need to be replaced. You can also pull out the element and do a visual inspection, sometimes you can see where the element coil is touching the housing. When the element is shorted out, it will continue to heat when the dryer isn't calling for heat. They will even heat with the dryer not running, so make sure to unplug it for safety reasons.
Jul 27, 2012 | Whirlpool Dryers
Quit heating
Hello there and thank you for choosing fixya
ok there are a few reasons why this happnes i will post them below for you
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Jan 22, 2011 | Dryers
Whirlpool TED5780JQ0
Hello there:
here are some helpfull ideas for you
  1. Examine the coils. If your dryer isn't producing any heat
  2. the terminal bracket that secures it may need to be replaced. Also check to see if the thermal fuse is blown, if both volt circuits are on and the thermostats are functional.
  3. Step Check the vent. If a load takes longer than one hour to dry clear the vent duct of any obstructions. Determine if the heating element is partially burned out .
  4. would get a new element anyway ok?
  5. I hope that this is very helpful for you
  6. best regards michael
Nov 18, 2009 | Whirlpool ET8CHEXSQ Dryer
Gibson electric dryer doesnt heat up
you may have shorted you thermal fuse. or the overload that is attached to the element housing. Good luck.
Apr 13, 2009 | LG DLE2532W Electric Dryer
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 | Dryers
Kitchenaid superba dryer won't heat Where is the heater fuse located?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ).
But darn it, I don't have a Ohm Meter....
To check the thermal fuse  - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out  - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity -  - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
How to take apart information for GE style dryers
How to take apart information for Inglis - Whirlpool - Kenmore dryers
How to take apart information for Maytag dryers
How to take apart information for Frigidaire and White Westinghouse
How to take apart information for Admiral, Norge, Magic Chef and Crosley
Mar 30, 2009 | KitchenAid Dryers
Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Oct 27, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool dryer
First make sure you have power to the unit through the plug. If power is present, then you most likely have an open Thermal Safety Fuse. The Thermal is a Safety feature that shuts off the power to the Heat Element in the event the Blower is not blowing or the Lint Vent becomes clogged not allowing air to flow over the Heat Element. NO air flow, Heat Element over heats, Thermal Safety Fuse opens, power shuts off. If the Thermal Safety Fuse is open find out why. Was the blower not working? Was the Lint Filter clogged? ( Lint Filter should be cleaned after each use to assure continued air flow.) Was Lint Vent Clogged? This is the Vent Hose that goes from the Dryer to the outside of your house. It should be checked for free air movement. The next thing-- Could be a defective Timer or Control Module.
Find where you lost power and WHY!!
Jan 27, 2008 | Dryers
GE Profile Harmony DPGT750EC Electric Dryer Logo
Top GE Dryers Experts
vince
gbob59
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
