Question about HP Compaq Presario V2000 Notebook
You've encountered error message C00D11B1 while using Windows Media Player
  • 91 Answers
What Version of Windows Media Player do you have? If you have an older version, I would recommend upgrading to the newest version to see if this overwrites the existing problem..
Posted on May 14, 2009
  • 433 Answers
My window media player 9 cannot rip music into other formats. Got this message on screen "You've encountered error message C00D10D2 while using Windows Media Player. Additional information is not...
I would suggest trying to install the latest version of windows media player,but if you are at work it may not be possible. Most companies try to block their employees from doing this at work. Thanks for using FixYa
May 13, 2011 | Microsoft Windows Media Player
How to solve error message C00D11B1
Computer program errors are discussable. First, the programs require compatibility to the entire computer system to take effects either as downloads or installation from internet of disk drives. Computer software programs have compatibility versions to each system innovated. For example, windows media player version 9 or earlier is installable on older computers where version 10 above compatible to recent innovated computers. In situations that computer least captures the window media player effect requires acquiring another media player. For example, real one media player has the compatibilities to generic device either Microsoft of apple Mac computers. Also, available are generic media programs that least requires compatibilities to install however least has satisfactory expectations discussable. Error observations are solvable either as attaining an alternate program software least incompatible or capturing a computer that is compatible to the program requesting installation.
Feb 28, 2011 | Microsoft Windows Media Player
How do i fix error code C00D11B1 Media player 11 ?
Recognizing and Fixing Media Player Error Code c00d11b1
For the majority of Windows Media Player users who encounter the Media Player Error code c00d11b1 message, the problem only begins after they upgraded to 11. In other words, media player versions 9 and 10 worked perfectly well for them.
So, one option is to 'roll back' the player to a previous model that did not encounter any such problems.
To do this, initially go to Start, then Control Panel, and Add/Remove Programs. Next, click on the Windows Media Player 11 icon and click Uninstall.
It will ask if this is really the option you want to take. Confirm that it is, and then be patient as it may take several minutes for the operation to be completed. During this time, it may appear as if your PC has switched itself off, but it has simply deactivated all unnecessary extraneous computer operations, in order to retain memory and processing power for the job in hand.
Next, according to Microsoft, when this particular error code is encountered when trying to stream online video or audio, it most commonly indicates that the proxy settings for Windows Media Player are incorrectly configured.
This can be checked from the Tools menu within Media Player itself, after whch you need to click on Options. Then you must click the Network tab and in the Streaming proxy settings area, you need to verify your settings. If you're not sure what the correct settings are, first, click on Configure, and then in the Configure Protocol dialog box, select Autodetect proxy settings.
In some cases, you can also apparently encounter this problem if Media Player tries to receive an online stream by using the User Datagram Protocol (UDP), but for some reason, it cannot do so.
You may be able to fix this particular error by turning off this UDP option in the Player.
If these solutions are not effective, your problem may be something as simple as Media Player trying to access the wrong audio or video device on your machine.
Open Tools, select Options, and then select Devices. When this comes up, make sure that the correct audio for your PC is checked, and this could very well make your problem disappear.
If none of these operations is effective, then you may well need to check the underlying registry of your Windows operating system for defects and errors that may be causing Media Player to malfunction.
Almost inevitably you will find errors and defects in your registry whenever you run a thorough scan, and whilst it may not necessarily be possible to isolate a specific problem that is causing Media Player to malfunction, the cumulative effect could be the root cause of your difficulties.
If, therefore, you already have software installed on your machine that can scan and fix your registry for you, then you should use it.
If not, you can still avail yourself of a free online registry scan using proprietary software such as SpeedyPC. Whilst you will not be able to repair your registry errors without downloading and installing the full version of the software, nevertheless, the scan will indicate the extent of the problems that you have, and these problems may be what is causing you difficulties with Media Player.
Or download this software after downloading, install this software and try vlc media player. This will install (codec) compressor/decompressor for audio and video more supported multimedia.
Nov 18, 2010 | Computers & Internet
Encountered error message C00D11B1 while using Windows Media Player
There are different solutions on your problem here I did find some of them:
Try to use ccleaner and be sure that windows media player is checked :
http://www.ccleaner.com/
1: try to download this codek pack and install it :
http://www.free-codecs.com/download/XP_Codec_Pack.htm
2: it is related to updates your error you have to do this :
http://drmlicense.one.microsoft.com/Indivsite/en/indivit.asp
3: try to remove all the files from this folder- C:\Documents and Settings\All Users\DRM\- to a new subfolder and try this :
moving ALL the files in the folder: C:\ProgramData\Microsoft\Windows\DRM\ as well as the files in the “Cache” folder beneath that was the magic trick. I don’t know if you need to move from both folders, . Note that media player had to re-download the licenses. If it not work you can always return them from the folder back.
For more solutions please see here from the source link :
http://strom.wordpress.com/2007/04/06/windows-media-player-error-c00d11b1-solved/
Hope that helps
IF NOT then return here
Please rate my answer
Other support places :
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/default.aspx
Oct 07, 2009 | Computers & Internet
WMP error message-C00D11B1
Can you try this:
  • Start-> Control Panel->Hardware and Sound
  • Sound / Manage Audio Devices
  • Highlight your audio device
  • Properties
  • Advanced
  • In the Exclusive Media section, UNCHECK the box "Allow applications to take exclusive control of this device."
  • Apply
Hope this helps.
Thanks.
Mar 08, 2009 | Microsoft Windows Vista Ultimate Edition
Error when I try to use Windows Media Player 10 or 11
This error is generally the result of a corrupt or missing Custsat.dll file, usually located in the C:Program FilesWindows Media Player folder.To workaround this problem:
1. Remove the current Windows Media Player 10 install.
2. Download and install
Windows Media Player 11 for Windows Vista
or
wm_tn_wmp11xp.jpgDownload Player 11 for Windows XP
I tend to use VLC Player, as it plays everything I throw at it..
Hope this helps
Chris (ziraffa)
Jan 05, 2009 | Microsoft Windows Media Player
Error message C00D11B1 comes up when playing video with microsoft media player, please help
Have you tried reinstalling the program?
http://www.microsoft.com/windows/windowsmedia/default.mspx
Choose Media player and let me know if you have the same problem again?
Aug 15, 2008 | Computers & Internet
Audio
try to uninstall the software and then the soud card of your computer.. then attach it again and install the software.
Mar 25, 2008 | Microsoft Windows Vista Ultimate Edition
I can not play audio files
In the windows media player go to > now playing - more options - devices - speakers then changed the audio device to use your soundcard.
Also, uninstall any other players, they usually interfere with each other.
HP Compaq Presario V2000 Notebook Logo
1,050 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
