Question about Zanussi ZEBF250W Bottom Freezer Refrigerator
The freezer is staring to ice up please help!
  • nprice1 May 14, 2009
    This is a Frost free fridge.......?
    Sergeant:
    Champion:
  • 214 Answers
Please switch off your refrigerator for at least 8 hrs. than again switch it on. i'm sure that the problem will be solved...................have a nice day :-)
Posted on May 14, 2009
Water leaking on freezer shelves no water in ice maker
Good Morning Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS26H5AS, is not making ice and is leaking water onto your freezer shelves. Please make sure that your freezer is cold enough. Your freezer should be set at a temperature of 0 degrees F. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FRS26H5AS Side by Side...
Freezer frost free
If it's iced up it's not the fuse. It needs defrosting so the air can flow again and refreeze your stock
Check the thermistor, heater and pcb timer, and clean the condenser to check it's not running all the time just to get to set temperature.
Mar 21, 2014 | Freezers
I have a maytag msd2758ge that the coils in the freezer stared freezing up and then the other day the unit stopped working
I'm Leo
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check evaporator fan in freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If this was helpful please rate me
Thanks for using fixya
Leo Ponder
imufo2
Jul 24, 2011 | Refrigerators
Freezer leak, Ice inside the freezer (AMADA ARB220ZC)
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 08, 2010 | Amana ARB220ZC Bottom Freezer Refrigerator
Top section not working
If there is a lot of frost build up on the back wall of the freezer section you are having a defrost problem and the coils behind that wall are filling up with ice restricting air flow and letting fan blades hit it. If not a lot of frost the evap fan motor is going bad which is also located behind the freezer wall. Good luck.
Feb 24, 2010 | Refrigerators
Ice maker not working/ ice will not fall in ice try/ please help
Hi: As summer approaches our refrigerators warm up. Your freezer has to be at 0degrees to harvest ice. Set your freezer colder and don't trust cheat thermometers. Also don't do the human thing and check the freezer every 30minutes to see if ice is made. It will take 24hrs at zero degrees and opening the freezer a lot will not help matters. Hope this helps, Jeff This happens to me every summer.
May 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice build up on freezer floor.
Hi, If ice is building in the freezer, you have a defrost drain hole plugged. Unplug the Fridge and then remove the rear panel off the freezer. There you will find ice built up in rain. Remove the ice (hair dryer works best). Once the ice is gone, you need to make sure the drain hole is open all the way. A baisting serringe with hot water works really well.
I hope this helps. Please let me know if I can assist you further. Please rate my answer so I know how I am doing.
Thanks
Vic
May 22, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
GE side by side not cooling or freezing
Sounds like you have a fan problem or more likely a defrost problem( timer motor or heater element) Most likely the defrost timer!
Jan 17, 2009 | Refrigerators
I have the automatic frozen yogurt-ice cream & sorbet maker ICE-20 series made bby CUISINART. The first few times the icecream came out perfect & great. I made ice cream yesterday and it was soupy. I put...
I would actually let the freezer bowl thaw out on a level surface. Then place perfectly level back in the freezer for 24 hours. Should work again. Enjoy!
-Tha Mp3 Doctor
Dec 10, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Zanussi ZEBF250W Bottom Freezer Refrigerator Logo
82 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
