Question about Dacor Preference RSD30 Gas Kitchen Range
Timer tone goes off with F1 display
DACOR gas stove and oven. Timer tone goes off with F1 display. ????????
    Genius:
  • 1,157 Answers
Hi arl3933,
The "F1" error code description is a System Watchdog Circuit. Please press "CANCEL", if beeping continues after 30 seconds, please check the main control board(ERC). Here are basic test that will help you to determine if the ERC or touchpad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back.
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 08, 2011
I have a dacor rsd30r which beeps and flashes F1
I am not sure, but I would set my clock to the correct time. Then I would insure that all the timers are set to not come on or shut off at a particular time. In other words, make sure everything is set to OFF. NO TIMERS, NO ALARMS, NO ANYTHING! I had a similar thing with my stove but when I turned everything off and made sure nothing was set to come on with a timer, and all alarms were off, including your minute minder, then that should take care of it.
Apr 24, 2010 | Dacor Preference RSD30 Gas Kitchen Range
Dacor RSD30S F1 Error Code
WHAT IS WRONG WITH YOUR RANGE / STOVE / OVEN?
small_13_33.jpg For a detailed Range/Stove/Oven illustration, click below.
redarrow.gif Gas Free Standing
redarrow.gif Electric Free Standing
redarrow.gif Gas Cooktop
redarrow.gif Electric Cooktop
redarrow.gif Gas Walloven
redarrow.gif Electric Walloven
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It's stopped completely
It won't bake
It bakes poorly
It won't broil
A burner doesn't work
A burner works only intermittently
I can't adjust the burner temperature
It won't bake or broil
The clock stopped
The temperature is wrong
The oven light doesn't work
There's a self-cleaning problem
The oven door won't close
An indicator light doesn't work correctly
The oven is hot on the outside
I see sparks!
The drip pans need replacing
hope this may help;
Regards,
VOTIT
Jul 30, 2008 | Dacor Preference RSD30 Gas Kitchen Range
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
F1 error code on gas/electric Fridgidaire oven
yes it would only give another error code.board about 100$
Dec 31, 2008 | Frigidaire FEF352 Electric Kitchen Range
Dacor cps130 wall oven f1 error
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Nov 06, 2008 | Dacor MCS130 Millennia Electric Single...
Error Code F1 on oven timer panel
I have the same problem as above. Is there any quicker way to get an answer from tech support. I have no stove or oven right now.
Sep 05, 2008 | Kenmore 46123 Stainless Steel Electric...
Dacor duel fuel range
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
Aug 19, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Jun 14, 2008 | Frigidaire FGF326AS Gas Kitchen Range
PCS 130 Keypad
Dacor probably won't cover anything. F1 is either the touch pad or ERC (clock). If it stops beeping when the touch pad is uplugged from the ERC then the touch pad is the problem if not it is the ERC. Call Dacor Customer service to get a price on the parts and to voice your displeasure.
May 22, 2008 | Dacor PCS130 Preference Electric Single...
F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Nov 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Preference RSD30 Gas Kitchen Range Logo
299 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
