Question about Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SKYBOX None of the lights light up and it wont despense? I replaced the flapper door censor and that didnt work? ANY IDEAS?
  • bocca Nov 09, 2007
    Same problem here too. None of the lights light up and it wont dispense? I replaced the flapper door sensor and that didn't work. any suggestions would be great.
I also had the sme problem and replaced the 12 volt transformer and that solved the problem
Posted on Dec 30, 2007
    Problem Solver:
  • 7 Answers
I had the same problem and it turned out to be the transformer. Remove the rear cover, and the cover over the black box on the right (as you face the rear). You will two red leads going to the PC board, remove that connector and test for 12v AC on those leads. Be careful since it has to be plugged in to test this. If any of that didn't make sense, or you don't have a voltmeter, best to call an expert.
Posted on Dec 28, 2007
Skybox will not dispenser beverage
ok i have the solution to the dispensing problems on the maytag skybox vending machine ... u need to open the main door and unplug the main harness , next remove the door from the hinges and place upside down somewere were it is good to work on ,next remove the 2 screws that cover the flapper sensor , next remove the seal around the door,behing the seal you will see a series of screws, remove all of them a regular phillips screwdriver is fine, next remove the back cover from the door, there you will need to unplug the flapper sensor from the main board just follow the cable and youll find the plug, once you have unplugged the plug continue by removing the complete sensor and wire, next you will see 3 wires one of the wires has xxxxxxx all over the wire this wire you will NOT touch as it can short out your unit now the other 2 wires you need to separate and cut once you have cut the 2 wires strip the ends and unite both ends together tape up and tuck away once you have done this put the door back together and mount on the unit and continue vending hope this helps .....
Dec 01, 2012 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox cools but nothing else works, no LED lights, no dispensing
If none of the LEDs are working, sounds like the transformer has went bad. First look at the board for a fuse to see if its blown, if so replace, see what happens next. To check and change the transformer you need a volt/ohm meter. If you do, and are feeling ambitious, I'll need some info off the schematic or the transformer itself, and I will walk you through it.
Dec 28, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Lights blink when drink button pushed.
Hello first check the flap sensor where the magnet in the flap is even.You will have to take the door off and apart the sensor is right behind the flapper door frame.Take 2 black screws out to get to the sensor.Moisture builds up on it and corrodes it.Clean it with alcohol,replace it and try it,this is just an easy trouble shoot it worked for me,though my chutes still dont go to the home position always but maybe yours is set right already.Good Lucke4aadca.gif
Aug 25, 2010 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox 1976AAB wont dispence
I had the same problem. The hinge pin on the dispensing door was rusted and this kept the door from closing completly. The door sensor magnet was not making contact with the door sensor and this caused the error. I removed the pin, sanded it down and it before reinstalling. It works fine now.
Apr 05, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox not dispensing
sounds like the ribbon cable that connects the mechanism set to the rear control board has become unplugged. I have a troubleshooting guide. email me at garymyers@insight.rr.com.
Apr 01, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Broken Door Hinge
go to www.apdepot.com enter your model number and a parts breakdown will come up you can order parts and they will ship to you
Sep 20, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox Flashing Lights
I had that problem too, in addition to a backwards cooling fan and the wrong thermostat. I needed to replace a sensor wire in the door, condensation had caused some rust on it.
Al
Aug 26, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox won't dispense anything
check the door where the cans come out. there is a sensor or the left side. if it is too far away from the door or if it's broken, it will do exactly what you said. i read somewhere that you can adjust the sensor closer to the door. i just bought one of the last one of these on the shelves 2 days ago and mine won't cool at all. stupid maytag..
Mar 01, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
82 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
