Question about Dacor EHD3618SS Kitchen Hood
Replacing a Dacor hood light ?
How do you replace the stainless steel rim that the light bulb sits into in the Dacor Hood?  It has 2 latching springs that  latcth under the bottom of the hood liner?  Thank you.
SOURCE: took off trim around lightbulb
Place the circle of the springs on the two small post that are in the center piece of the trim that heads into the hood, make sure that the two legs of the springs are to the outside of the post. The small legs should lay against outside the center piece. The larger legs should be angled downward. Look in the hood and you should see a piece of metal with a central vertical opening on each side. Take the trim piece with the springs attached and lift the wings of the springs so that they enter the slits. The important part is that the small legs of the springs must be placed against the outside surtace of the hood. As you push the trim piece in the hood the wings of the spring will be forced down through the slits by the pressure of the small legs of the spring against the exterior of the surface of the hood. This pressure will keep the trim piece in place. It may help to remove the filters so that you can see inside of the hood. Make sure that the small legs of the spring are against the outside surface of the hood or there will not be any resistance to create pressure by the springs.
Posted on Jun 04, 2009
SOURCE: dacor downdraft vent
dacor down draft ventilation won't turn on
Posted on Dec 27, 2007
SOURCE: Dacor oven light bulb
Yeah, it's a rip-off isn't it? Been there. :-( Find the bulb part number or electrical values and search eBay. I think this is what you're looking for:
G4 halogen 12v 10w, dacor part 86364.
A search right now shows multiple vendors offering 10-piece packs for $7.00 including shipping. I'm about to order a set myself.
Posted on Nov 24, 2009
SOURCE: how do you get the light bulb out of the hood?
there is a tool (suction cup) that dacor provides with unit or you can order the "kit" online for $30. i used some gloves with latex coating on palms to get "decent grip" to spin it out. that stainless stell rim actually pops out on my ventilation hood....it is similar to recessed lighting baffles...spring loaded....it may give you a bit more room to manuever your fingers.
Posted on Sep 06, 2010
  • 83 Answers
SOURCE: Dacor Epicure ER48D Stainless Steel Gas Kitchen
go to this website for your reviews and ratings www.retrevo.com
Posted on Sep 17, 2010
Can't replace light bulb for dacor hood it's 4 yrs old
did you try to remove the filters to get to the bulbs?
Jan 23, 2011 | Dacor EHD3618SS Kitchen Hood
Put new bulb in baumatic kichen hood turned it on, instantly made a noise like it tripped out, fan and lights now don't work, can not find fuse?
It was probably a defective bulb that tripped a circuit breaker in your house panel. Check the breakers and replace the bulb.
Feb 24, 2010 | Baumatic F60 Stainless Steel Kitchen Hood
How do you get the light bulb out of the hood?
Sep 30, 2009 | Dacor EHD3618SS Kitchen Hood
How do you take out light ballbs from dacor hod fan
To replace the light bulb:
1. Remove the right filter and turn off the main power
switch.
2. Gently push the suction cup on the light replacement
tool A (provided with you range hood)
onto the lens of the light bulb B .
3. Turn the tool counter-clockwise until the bulb
comes loose.
4. Remove the tool from the bulb and put it on the
lens of the replacement bulb.
5. Screw the new bulb into the light fixture clockwise
until it is tight. Turn on power at the fuse or junction
box. Turn on the main power switch and touch
the light key to make sure it is working.
6. Replace the filter.
You can download the manual here.
Good Luck And please Rate FixYa!
Dec 19, 2008 | Dacor EHD3618SS Kitchen Hood
Lightbulb Dacor Hood
simply remove filter screen from hood (might as well clean it while it is out), reach your hand through the opening, grasp the light bulb and turn clockwise to remove.
had same problem myself and this is what i did.
Feb 23, 2008 | Thermador 36'' HTSW Series Stainless Steel...
Dacor IVS1 Vent Hood - How to change a light bulb?
Buylighting.com, JDR120V-75W-E27CG...also comes in 50 watt. They aren't inexpensive, but if installed properly, will last a while. We have a little suction cup to take them out and put them in. It came with the range hood. If you get fingerprints on a halogen bulb, it can blow out quicker.
Dec 30, 2007 | Kitchen Ranges
Dacor downdraft vent
Call Dacor at 800 793 0093. They'll tell you who has the part.
Dec 03, 2007 | Dacor RV36SS Kitchen Hood
Vent Hood
when a bulb blows, it takes excess current. if breaker is not sized to a hood, then damage to module can occur at time bulb goes
Apr 20, 2007 | KitchenAid KHTU165RSS Stainless Steel...
Dacor EHD3618SS Kitchen Hood Logo
627 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
