Question about Gateway FPD2275W LCD Monitor
Computer Monitor Compatibilty
I am thinking of buying an HP 24 inch monitor for my 4 year old Dell 8400 Dimension desktop system. Can I expect this new monitor to be compatible, possibly with some display setting chnages required at the most? Thanks nicktsa@aol.com
  • 490 Answers
Dear nicktsa
You need to put either new dispaly card or AGP card in dell pc (it supports) to get proper resolutaion of monitor
thanks
Gizmo
Posted on Oct 15, 2007
What do I try to get 17" dell 1908pf monitor to stay on? Just goes to black screen after a couple seconds.
If it is a 1908pf, it is classed as a 19 inch monitor, not a 17 inch. Notwithstanding, the device is approximately 8 model years old, which makes it a senior citizen for computer monitors. Most likely candidate is the ballast (inverter) for the backlight system going bad, or the florescent backlight bulb itself is failing. These CAN be repaired, but as old as this unit is, you are better served buying a new one. Modern TVs/monitors can only be expected to last a little over five years anymore. The backlighting circuits are their weak points. Manufacturers are not interested in improving this, since they want you to buy a new unit every 4-5 years, rather than every 10 years as was the case in the CRT days. "Planned obsolescence", as we like to call it, is not unique to TVs either. Newer appliances (fridges/ranges/dishwashers) are all being made "better", meaning all kinds of bells and whistles, but engineered to last half as long as their predecessors. Apparently we can't have it both ways.
Oct 31, 2015 | Dell Computers & Internet
My Dell Dimension 8400 desktop computer using Windows Xp operating system. The monitor shows the Xp Logo at first. Then the screen goes blank about 30 seconds into the boot process. What can I do to g
If you hit <F12> key upon boot-up and the monitor displays a boot menu, then you probably have an issue with your XP software. Meaning that you may have to re-install XP (by the way, XP is no longer supported).
Jan 28, 2012 | Dell Dimension 8400 PC Desktop
I have a 7 yr old Dell Dimension 2400 with a 17" Dell E171FPB flat panel monitor. Frequently, but not always, the monitor will flicker on/off every few seconds then go black for several minutes. It has...
Find somebody with an old CRT-style monitor -- they are essentially WORTHLESS -- because they take up too much space, and not as nice a picture as an LCD, and offer to take it off their hands. Use it as a "test" monitor.
Or, it could be the video-card in your SEVEN-year-old computer.
Try replacing the video-card -- some friend probably has a "dusty" and "spare" video-card that can be temporarily used.
Jul 30, 2010 | Dell Dimension 2400 PC Desktop
What is max size HDD for a Dimension 8400
As far as I know, there is no known maximum size. If you are making it a slave drive, you need to go into your system's BIOS and tell the computer you have a new HDD.
Restart your PC, and you will either need to hit your F2 key or Delete key repeatedly on boot. Just watch the top right corner of your monitor to know which button to hit.
Once you're in BIOS, just move to the hardware section or hard drive section and make the necessary changes.
Reboot and enjoy!
Feb 23, 2010 | Dell Dimension 8400 PC Desktop
I have an old (5 years) DELL PC with a CRT monitor. Of late the display has on the screen appears to be vibrating a little. This is causing eyestrain. The brightness, clarity & colours of the display...
The monitor is probably faulty. To determine if the monitor or the video card is faulty, connect a different monitor to your DELL. If the image is OK on the other monitor then the other CRT monitor is faulty. Repairs to the CRT monitor may not be a cost effective solution, I suggest you buy a LCD monitor.
Feb 05, 2010 | Dell Dimension 3100 PC Desktop
Monitor does not light up
1. try the monitor on another system.
Did not work?
2. you need a replacement card inside the monitor this card is where the vga cable connects to the monitor.
or
3. you have a bad connection or solder joint inside the monitor.
4. if it does work on aother computer check your current computers video card.
Thanks I would love to hear your feeback on our service.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 22, 2009 | Dell Dimension 3000 PC Desktop
Monitor blinks on and off.
Try this, open your computer case and look at the monitor connector thing. Is it plugged in correctly? If not, plug it in. If it is, buy a new monitor connector, they are somewhat cheap. You can install it by yourself, all you need is a screwdriver.
Sep 12, 2009 | Dell Dimension 8400 PC Desktop
Dell dimension 8400 beeps 6 times monitor dosen't turn on
Below is a link to the beep and light codes for a Dimension 8400. Check your codes and reply back if you need further assistance.
http://support.dell.com/support/edocs/systems/dim8400/SM/adtshoot.htm
Jun 03, 2009 | Dell Dimension 8400 PC Desktop
Gateway FPD2275W LCD Monitor Logo
138 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
