Question about Timex 27191 Wristwatch
Keeping time and indiglo light not working
I recently had a new battery installed and since then the watch does not keep time right and the indiglo light will not work when the button is pressed. What can I do to resolve this problem ?
  • 6 more comments
  • Booboonff Nov 25, 2007
    I REPLACED BATTERY AND NOW STEM WONT STAY IN AND WATCH STOPS AND LIGHT DOESN'T ALWAYS WORK
  • lodac Dec 06, 2007
    I replaced the battery on my wr 30m Indiglo watch, the indiglo works fine, then stem also works fine, watch runs for about 1 minute then stops again.
  • Anonymous Dec 22, 2007
    The light on my indiglo timex has gone out, how can I get it fixed? New battery or what? Thanks
  • Anonymous Feb 04, 2008
    I have 3 timex expedition watches that worked fine, until I changed the battery. Now they don't work at all! Timex, "takes a lickin' and keeps o tickin'", until you change the battery.
  • Anonymous Mar 31, 2008
    I changed the battery and now the watch works fine but the light does not work when I press the "Indigo" button.
  • Anonymous Dec 28, 2008
    My light does not work on Timex Expidition watch. How do I fix it?
  • Anonymous Mar 30, 2009
    I replaced the dead battery in my Timex Expedition Indiglo with the required 2016 battery (major brand), and watch works fine for all functions except light does not come on when pressing Indiglo button. I have removed watch works from body and checked all contacts, and placed small screwdriver across light switch contacts, but light still doesn't come on.
  • djensen9 Apr 26, 2009
    I just replaced my battery and now the watch won't work at all and the indiglo light won't work either.what can I do?
Check to make sure the button is making contact with the circuit board. It may need to be adjusted. Try and manually make contact with the copper contact. If it lights, then just adjust the tab.
Posted on Feb 10, 2009
Might light no longer works, had battery checked and it is fully charged. Please advise
the indiglo of your watch is probably busted, you had to replaced its dial. the the battery has been checked but not the watch by a new battery? try to check the watch by a new battery. if still not lighten up check the connection of the button it probably cannot connect the connections of the light. i hope this advise will help you a lot.
Sep 08, 2011 | Timex 2D421 Stainless Steel Perpetual...
The light in my watch stopped working. How do I get it fixed? It is a Timex Indiglo(ladies) I don't have any other info.
Most watches of this type have 2 batteries - 1 for the light and 1 for timekeeping. If you use the light a lot, you may have flattened the battery but the watch keeps going because it's running on the other battery. Take it to your local jewellers/watchmakers/watch repair shop and get them to test the battery and replace if flat. If the battery isn't flat and the light doesn't work then you have a faulty watch - if it's still under guarantee fine, if not buy yourself another watch if you can't put up with the fault.
Jul 29, 2010 | Timex 27191 Wristwatch
The light was fading on my Indiglo Timex watch but it was still keeping good time, so I had a new battery installed by a Walmart employee. The light now works on the watch but the watch stopped keeping...
mcdevito75 here, Your Timex watch is most likely an Indiglo meaning light, The battery supplies power to to Quatz mechanism for time keeping and for the light. There is a very good possibility that 1 or 2 of the contacts between the battery and the Quatrz mechanism were lost during the new battery installation. While you can"t rule out that the Quartz mechanism and or the light may be wearing down, you still have to suspect the battery even a new battery, look for a small watch repair shop in your area and try another battery, let the jewler know of your watches problem so he / she can properly install the battery and ensure the contacts between the Quartz and the battery are being made.
Jul 07, 2010 | Timex 27191 Wristwatch
My watch has stopped keeping time but i can still hear it clicking. The indiglo still works as well so its not the battery. i will change the time and it will work again untill about 30 seconds to 1 minute...
Quartz watches do get gummy or dirty gears and slow down or just quit. I know that I have the cleaning chemicals that generally works to unstick the gears, but I also have the equipment that pulses the watch with enough power to get the mechanism working again. If that doesn't work then it's time to replace the movement with a new one. This is generally cheaper than spending lots of money on the labor to get the old movement working again. Best of luck on this one.
Nov 04, 2009 | Timex Expedition 40141 Wristwatch
After about two years, my indiglo night light function stopped working. The watch is still working, keeping time. Will changing the battery fix the indiglo problem?
Definitely, battery change will solve the Indiglo light problem. Many of wristwatches has separate battery for Indiglo function, but my advise is to change them both at once - will be cheaper for you.
Rate me, please.
Sep 01, 2009 | Timex 2J611 Watch
Timex T49271 Expedition Indiglo button dead?
There is no separate battery for the indiglo,maybe indiglo circuit is lose or defected already,just open the watch and check for lose connection.If happen the circuit is tight and still not working then replace the indiglo circuit.
Hope it may helps you;
Regards
VOTIT
Mar 23, 2009 | Timex Expedition 40141 Wristwatch
Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
Dec 30, 2008 | Timex Watches
Men's Timex Indiglo large face watch battery problem.
Remove the battery and check the contacts at the bottom of the cavity to be sure they haven't gotten mashed flat. The cell should seat firmly in the cavity, not just rest in it. Be sure the back is seated firmly.
Feb 19, 2018 | Timex Expedition 40141 Wristwatch
Repair or buy new
WELL YOU SHOULD START WITH A NEW BATTERY ALWAYS A WORTHWHILE CHECK AS THIS COULD BE THE PROBLEM.. ASK ? PLEASE REPLACE THE BATTERY IF MORE THAN THIS QUOTE FIRST
Jul 20, 2007 | Timex Ironman 53151 Wrist Watch
Timex 27191 Wristwatch Logo
10,085 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
