Air conditioner does not engage
I put over 4 pounds of freon in the air conditioner of a 2006 International 7600 dump truck - still does not work. The clutch can be turned manually so it's not frozen but it does not engage when unit is turned on.
  • iraleee May 22, 2009
    Do i need to evacuate the system of refrigerant before i can change this switch? The motor is a Caterpillar ACERT system.
    Problem Solver:
  • 14 Answers
Hi iraleee any updates for this concern, because we've got a solution for you, please reply.
Posted on Sep 23, 2009
  • 8,220 Answers
You probably have a bad low pressure cutout switch.
Posted on May 14, 2009
  • Dan Webster
    Dan Webster May 22, 2009
    I believe you will loose what is in there if you don't evacuate the freon.
    The ideal thing would be to connectit to a machine and remove the gas. Then replace the switch and vacuum the system. Then install the
    Correct charge there by weight. It should give the correct amount somewhere on the machine.
Where is the expansion valve located on a 2005 international 7600 dump truck?
Newer units don't use an expansion valve, but instead just an orifice tube, usually located in the junction of the high side hose to the evaporator under the hood.
Sep 27, 2016 | Cars & Trucks
Air conditioning system freon
You'll need to have a mechanic check the system to see if it is low on freon, or if you have an electrical problem.
Jun 09, 2013 | 2008 Mitsubishi Galant
My 2006 chevy trail blazer air conditioner air will not come on what could be wrong?
check fuse or could be low on freon ,if that dont work ,check make sure the clutch is engaging when on . clutch on compressor.
May 27, 2013 | Cars & Trucks
My saturns air conditioner isn't working correctly is the antifreeze mix wrong
no coolant problem will cause a heat problem sounds like you have a low freon charge in the ac system if empty the system hold 1.5 pounds of freon
Jul 01, 2012 | 1999 Saturn SL
How many PSI freon dos this unit take to fill? S3QA-30KA 2.5 TON
unit's are usually charged in pounds not psi...units require a certain pound amount of freon to work properly....... it depends on the outside air temp, the inside air temp.... what type freon ?? need more details on unit and what type freon does it use??
May 10, 2011 | Heating & Cooling
Air conditioner only works while moving. The AC stops cooling when stopped and idleing. Anyone know what causes this?
Your freon level is low, and not circulating on slow compressor speeds. Stop by any shop that has a sign stating they work on a/c and they can recharge it for you in a few minutes. Here where I live they charge about $20.00 labor plus a charge for the freon they put in, they sell it by the pound.
May 25, 2009 | 2005 Jeep Grand Cherokee
My 96 grand prix's air conditioner compressor will not turn on when the switch is activated. I have replaced the large fuse under the hood but that still hasn't solved the problem. The indicator light on...
that light goes on mostly likely cause you need freon. the compressor will not go on if there is no freon. buy a userfriendly can at autozone. put it in low pressure valve(blue)  if it works but no cold enough air check under your hood for the proper pounds or ounces needed of freon.  if it doesnt work its your compressor.  GOOD LUCK! :)
Apr 25, 2009 | 1996 Pontiac Grand Prix
Heating & Cooling Logo
320 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
