Question about Whirlpool Dryers
Drum Will Not Spin
Drum will not turn
    Problem Solver:
  • 6 Answers
Most likely the belt is broken. Pull the sides off the dryer, top and front panels off also. see if there is a jam in there, (possible creature or something) don't laugh. It is common to have snakes crawl up there and get caught in the belt system. If there is no jam then check the belt. Replace it with your manuf. specs for your unit. Dryer are not that hard to work on, just remember where all your screws and wires plug in. color code the wires and screws so you have no extra stuff laying around when your done putting it back together. :O
Posted on May 14, 2009
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Motor smell hot drum will not spin or pump out water Maytag atlantis
Im not an expert, but.Ok, but it wash? The only problem is at spin? if not wash at all:
Disconnect from the outlet, remove the belt, and by hand turn the pump and drum. Its suppose to move with low resistance in both directions, will not spin freely, but turn easy by hand. Do the same with motor. IF the drum and pump moves in both directions, I suspect about the motor.
If the only problem is at spin:
Do the same, but place special attention at the drum when you turn in reverse. Look if you see the brake Disk turn.
Nov 27, 2011 | Maytag Atlantis MAV6000 Top Load Washer
The drum is not turning during spin cycle. Im
I think your question might be in the wrong Category
and yet I believe you are correct that you suspect that it's your clutch if you are speaking of a washer?
May have to call you local Lonely Maytag Washer tech.
Blessings,
A/V Media Tech Guy
Dec 02, 2009 | Televison & Video
Dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Nov 01, 2009 | Dryers
Drum will not spin. The belt is not broken but is hanging lose
If the motor is working...Shut off the power to the dryer, reach inside the drum and try to rotate the drum 1/4-1/2 turn. Sometimes the motors get dead zones in them and this will help move it out of the dead zone
It could also be the drum rollers that need lubrication or replacement, if they are not rotating it would not allow the drum to spin.
I hope this helps
Oct 02, 2009 | Kenmore 73952 Gas Dryer
Dryer drum will not spin when you push start button.
can you hear the motor running? if so its probably a broke belt
Sep 03, 2009 | Dryers
Washer won't spin. Belt is slipping. Tub is stuck.
The belt sounds worn out since its slipping. Change it out. Its cheap fix.
The drum brake does just what is sounds like. brakes the drum. For instance when u open the lid during a cycle and everything stops thats the drum engaging and stops the movement of teh drum. If the brake is malfunctioning two things will happen, you open the lid (assuming the safety switch is still good) or the drum will not spin at all.
Aug 24, 2009 | Maytag LAT3600A Top Load Washer
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
Drum will not turn
check the belt if its not that the the brushes need replaced in the motor that will fix the spin problem
Mar 03, 2008 | Indesit W 123 Front Load Washer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
