Question about Performance Teknique ICBM-892 Car Audio Amplifier
I cant stop the whine
I cant stop the whinning noise i have my amp grounded to the frame but it stii does it my power wires are on the oppisite side of the car from my rca jacks how can i stop this and i tried a ground loop isolator and it didnt help
  • 4 more comments
  • Sean Rodgers May 14, 2009
    it only happens when the car is running and it does change frequency when i step on the gas
    thanks for your help and for gettin back to me so quickly ill give it a shot and i learned something to i now know what dirty power is thanks
    i will thank you
  • Sean Rodgers May 18, 2009
    ok i brought a farad 1.0 and its till making the noise what can i try next
  • Sean Rodgers May 19, 2009
    thanks again for your quick responce ok ill try it thanks
  • Sphynkter
    Sphynkter May 11, 2010
    Does the noise only happen when the car is running or does it whine when the car is off? For example, the stereo is running on battery in accessory mode? Does the whine change frequency or is it constant?
  • 221 Answers
Ok, if it only happens when the engine is running and the noise changes with the gas, that's alternator whine. Alternator whine is caused by the ambient noise in the voltage which is produced by the alternator. Alternators don't make DC current, they make AC current. The AC current is then converted to DC current and then sent to the rest of the car. The noise comes from an imperfect conversion from AC to DC. That noise travels down the power cable to the amp and causes noise in your speakers. This is often called "dirty power". Dirty power can be variations in voltage, inconsistent current, or noise within the voltage. One of the simplest ways to clean up noise in a car stereo system is to use capacitors. If you add a capacitor to your system just before the amplifier's power cable, it will help filter out the noise from the alternator. Start with 1/2 Farad or 1 Farad. That should be plenty to clean up the noise. The capacitors will also have a positive effect on your amplifier's thermal and sound performance, but you may not notice it.
Posted on May 14, 2009
  • Sphynkter
    Sphynkter May 14, 2009
    Glad to help. If you found this post useful, please rank my responses. Have a nice day!
  • Sphynkter
    Sphynkter May 18, 2009
    Did the capacitor change anything? Where is the cap installed? and how? There should be a thick power cable coming from the 12V+ system into the positive terminal of the cap, the negative terminal should be well grounded to the chassis. You can even run a second lead from the cap directly into the power input of the amp to be sure that the power passes over the cap before the amp. Also, you need to make sure that all the grounds for the car battery, alternator, amp, and cap are really clean, tight, and using high-gauge cables. You should be using at least 4 gauge cables for ALL power and ground cables. If your alternator uses a thin little cable that's all rusted or corroded, you'll need to replace that, too. Alternator whine is always a case of dirty power - we just need to find it and get rid of it.
Honda crv whinning noise
When you first start the car up it sounds like a power steering whine. Have you checked the fluid level? Also get inspected timing belt ?
For step by step troubleshooting click the link below:
http://fexya.blogspot.com/2016/06/honda-crv-whining-noise.html
Thanks.
Jun 06, 2016 | 2012 Honda CR-V
Amp is making a whining or howling type sound
Sounds like Ignition system interference...Does whinning sound correspond with the accelerator? Make sure ground is isolated....and power is seperate from other circuits. ( ie; straight to battery with an in line fuse installed in it.)
Jun 05, 2014 | Rockford Fosgate Car Audio & Video
Whinning noise when engine is off
Whinning Causes
The whining noise you hear coming from the power steering pump is one of three things. The first is more of a loud "hush" than a whine; this is the sound of fluid rushing through the bypass valve when you turn the wheel all the way to one side or the other. Sometimes the bypass valve malfunctions or doesn't open all the way, causing pressure to back up in the pump and cause your engine rpm to drop. The second and third causes result from cavitation -- vacuum pockets created behind the rotor's vane blades as a result of extremely high pump action -- or air in the lines.
Nov 24, 2013 | 2003 Mini Cooper
When I turn my dvd player on, the volume will lower on its own to almost mute. It is hit or miss weather or not the unit will turn off on its own saying protect. All connections are good. Inside is clean....
When you've got good volume, try unplugging the speakers (only for a very short time) to see if that whining noise is still there or if it's stopped. We're trying to see if the whining is related to the low volume and "protect" or if it's only coincidental.
Try unplugging all the cables (except the power cord). Turn the player on & off several times & see if that whining noise acts the same. Also see if the player goes into "protect". What we're trying to do here is see if it NEVER goes into "protect" with the cables unplugged.
Last... try to get it to start & run without going into "protect", with all the cables unplugged (except power). Plug the cables in, one at a time, and see if plugging one of the cables in forces it into "protect". If so, there's something wrong with that cable or whatever's on the other end of that cable. Unplug it again & restart the player - no "protect"? Wait a little while, plug the cable in. "Protect"? Check the other end of that cable.
If it goes into "protect" with nothing plugged in except the power, then the player is probably a write-off, ready to be replaced (it's not very often that DVD players are worth repairing these days).
Nov 05, 2013 | Samsung HT-Z310T Theater System
I have a really bad alternator whine in my speakers ran by an amp. I cant tell where it is coming from. I've add grounds to every thing metal that I could find. But could hardly tell a difference in the...
A high pitched, consistent wining through your speakers is usually caused because you have ran your input wires from your deck to your amp along side your amps power wire. Can also happen if your speaker wires are ran with power wires as well. If moving the wires away from one another does not work. Try installing a noise filter.
Sep 12, 2009 | Car Audio & Video
Whinning noise coming out through my subs
Try using a bigger ground wire (#2 or #4) and as short as possible to the frame. Make sure the power wire (#8) is also ran from the battery as for away from any other electrical wire or from the alternator. Good luck and hope this helps, keep mepost5ed if you have any more questions. Be glad to help you get your Yukon sounding 100%.
Aug 22, 2009 | 2007 GMC Yukon
Feedback problems
hi there
that is a big system
well common problem with feedback is the power wires connected to amps and the RCA wires run from the pioneer unit to the amps are too close to each other if the power wire from the battery to the amps are run down (left) side of car make sure RCA and remote wire are run down the (right) side of the car if this is done like this than it could be the RCA cables you are using the other thing is if you rev the engine does it get louder if this is the case then the noise you hear is the alternator of your car to get rid of the feedback look at your amp power wire and load it with electrical tape or buy a piece of dynamat and place it around the amp power wire this will stop that...........if what i just said doesn't happen when you rev engine than ground each amp to its on metal frame (do not ground them together) this should also stop the feedback. make sure all RCA cables are no where near the amp power cable from your cars battery
hope i was able to help
Feb 28, 2009 | Pioneer DEH-P2900MP CD Receiver...
IM getting a whinning noise from my speakers on my 2nd amp
CHANGE YOUR REMOTE WIRE TO A SINGLE LEAD, AND THEN CHECK ALL YOUR CONNECTIONS.
GOOD LUCK
Dec 11, 2008 | Car Audio & Video
Alternor noise
I had the same problem with my Pioneer Head Unit.
I changed the ground of the Head Unit and the AMP to the same location and that took care of the Alternator noise.
Best of Luck.
Nov 11, 2007 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
Performance Teknique ICBM-892 Car Audio Amplifier Logo
467 people viewed this question
Top Performance Teknique Car Audio & Video Experts
George Nalley
Level 1 Expert
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
