Question about HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard
Have dv2125 hp laptop. unit will light up, but no picture. Then after turning on and off manny times it will come on and work for about a week. then i have to go thru the process again. any ideas senior66
    Sergeant:
    Novelist:
  • 197 Answers
It sounds like you're having a power supply issue. I had a computer that wouldn't boot up if I had certain USB devices connected that drained power. Check how much power your PSU puts out (the big metal box that the power connects to inside the computer), a good healthy number is around 400-500 watts. The one I replaced was only 220w, a minor oversight, but enough to cause me months of frustration, and booting up my computer with only the neccessary devices connected.
Posted on May 14, 2009
HP Pavilion Entertainment PC Laptop DV2000
when you say some times it keeps going does this mean the unit turns off ??,,,,this model has the gpu problem,,,dry solder joint of the graphics card, of which you can have the board repaired or replace the board
Oct 06, 2012 | HP Pavilion Computers & Internet
Red wireless light wont turn green, no wireless connection found, stays red all the time dv7-1020 pavillion notebook, no wireless switch that i can see just the light in upper right, stays red, all the...
I have a tx 1000 with pretty much the same problem. Short answer is : if you are still under warrenty demand that hp replace the entire unit (basically they put together a lousy design, it doesn't allow for adequate ventilation and consequently the motherboard cooks itself and other components attached to it. swapping out parts will only briefly "fix" the problem.
the simplest cheep fix is to get a usb wifi adapter and connect with that (untell eventually the machine will cease to boot, lights will come on fans will run but nothing else will happen)
and you like me will not only be the proud owner of a really cool looking paperweight but also will never consider buying anything from HP again.
Oct 10, 2010 | HP Pavilion dv7-1020us Notebook
Laptop Lid will not open
There are two metal hinges that are on that laptop model and are at top of laptop near keyboard and screen joint. When one of these hinges breaks, and they do, it can become jammed. By continuing to try and open it you run the risk of damaging the LCD on the laptop. The top of the laptop has to be removed to access the hinges and replace them. This is not something a novice can do easily and is dangerous to the laptop. If its not under warranty and you feel comfortable with your skills you can try. However I would recommend a repair shop. The hinges for this model run about 10 dollars for the pair and the labor would be whatever the local rate is. To see the hinges that are for your unit.. this link has a good picture http://battery-adapter.com/product_info.php/products_id/3463
Sep 27, 2009 | Computers & Internet
I have an HP Pavilion dv2125 with windows xp media center edition. When I turn it on now the bottom bar won't come up. Tried shutting down, pulling out the battery when it wouldn't shut down, but same...
click on start button your keyboard, go to control panel, click on taskbar and start menu, check the box displaying auto hide task bar and click on apply, uncheck the box again and click on apply then Ok
Aug 18, 2009 | Computers & Internet
Have lost charger and battery number for model number9918 please help
from the picture you have here, That I see you have a Wahl 8554 Wahl Alpha cordless clipper. but you stated the model 9918-6171 Groomsman Beard and Mustache Trimmer model, You need to be sure of what model you have. He are the two picture of each model. if this is correct, Mannys Sharpening has the charger for this cordless clipper, I had the same problem and he sent me one it took about 2 weeks for delivery.
27a92b7.jpgThe clipper on your Left is Wahl 9918
3283d36.jpg This clipper is the Wahl Alpa 8554 cordless
Call Mannys Sharpening he has all the replacement charger for Wahl.
323 263-4697
Jul 28, 2009 | Wahl 8554 Hair Trimmer
Message that battery needs replacing last week but it was still going
Remove the battery and ac adaptor. also remove any peripherals.
Make sure that ac adaptor is working ok
Then press power button and hold that for 20 seconds to statically discharge the notebook. Then plugge that into the mains (without battery) and try to turn on. IF Notebook will not boot. Call service as mainbord needs to be replaced.
May 27, 2009 | HP Pavilion dv9000z Notebook
NO SOUND ON A NEW HP DV4
sounds like it's a physical problem not software, but to be sure i would update the audio drivers and see if that helps.
go here and pick your system and follow the steps to get any new drivers and install and see what happens.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=dv4&submit.x=0&submit.y=0
please, Let me know :)
Dec 24, 2008 | HP Computers & Internet
Hp Pavillion laptop
Can you try booting to an external screen? If it works with an external screen, sounds like either the inverter (probable) or the backlight has gone out. If there's no image on the external screen, it could be any of several things, the most likely of which is the video module.
Sounds like you got a lemon. The DV series have been good sellers, and mostly good units.
Good luck
Oct 23, 2007 | HP Pavilion dv4000 Notebook
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
Mar 31, 2007 | Sony KV-27FV16 TV
HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard  Logo
477 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
