Question about AAD C10 Subwoofer
Popping during action scenes at moderate volume
Subwoofer pops under high intensity home theatre scenes even on moderaste volume
    President:
  • 1,348 Answers
The woofer is being overdriven and the voice coil is hitting the magnet structure.eventually it will damage the coil end and it will scrape in the gap.
Posted on May 15, 2009
Hot
Is this heat shows up when they are playing moderate to high volume level?
Jul 14, 2012 | Behringer Eurolive B212A Speaker
Hi gotta problem wid my bush home theatre..the subwoofer aint workin and even wont show the volume tried switchin on n off but still aint workin n i've also tried 2 swap de sockets no changes.It was...
It is probably an issue with the sub amplifier, but could be a blown speaker if it has been driven too hard. If you bought it new within the last year then you should be able to get it repaired under guarantee at the shop you bought it from.
Sep 10, 2011 | Bush Audio Players & Recorders
I have the velodyne DLS4000R and it keeps popping at high volumes ??
Popping ????? if popping sounds mechanical: chek for speaker blowned (replace or repair speaker)
if popping sounds electronic: chek circuitry.
Apr 03, 2011 | Velodyne DLS4000R Subwoofer Speaker
I have a JM Labs Cobalt SW800 subwoofer connected to a Yamaha RX-V2300. Recently during intense moments, esp action movies, the SW occasionally emits a loud pop; most of the time only one, but sometimes...
What you may be hearing is the speaker's guts bottoming out as it attempts to keep up with the amplifier, which may be clipping - a potential fatal thing to do to any speaker.
Maybe you should turn the volume down or run through the volume setup again and make the subwoofer equal in loudness to the other speakers and avoid excessive bass boost.
Feb 22, 2010 | Jmlab Cobalt SW 800 Speaker
Panasonic home theatre keeps making a popping
try cleaning all your connections for your speakers with isopropyl alcohol and a q-tip, if no luck it could be an internal problem
Jan 09, 2010 | Panasonic Home Theater System System
Tv switches off for a couple of seconds when the screen has a white flash.
It will be most likely that the board needs reworking because of dry joints somewhere, and to complement what bernardlunda has said, I have seen it too many times before myself where the customer has left it and popped the power supply too. cheaper for you to get it sorted now.
Apr 29, 2009 | Bose 901 VI Main / Stereo Speaker
Logitech Notebook Quickcam (SOUND PROBLEM)
Normal 0 If you have your speakers turned up to high it will give you feedback causing distortion and static. Sometimes even awith the speakers turned down low, feedback is possible.
I recommend using a headset when videoing. Hope this is of some help. Bud
Apr 22, 2009 | Logitech QuickCam Webcam
Speaker error
Try checking the volume on your subwoofer i had the same problem. I unplugged the system and had the same error message pop up. So i checked the volume on the subwoofer, and it was set to max, i set it to normal and i haven't had any problems since
There are 2 ways to check your volume
1...On the remote there is a button labeled "BASS" press it, and on the display it will tell you a number between -3 and +3, If no number appears then it should say either "MIN" or "MAX" if it's at max use the volume control on the remote to turn it down to "0"
2...On the remote press "SET UP"
.....Select the Volume icon by using the arrow keys, press "ok" or "enter" to access that icon
.....Select "Speaker Setup" using the arrow keys and enter button
.....Select Speaker Volume by pressing enter
.....scroll down to "SUBWOOFER" and make sure the volume is no higher than +4dB
....Once done press "SET UP" on the remote to exit the setup screen
*Note* - The speaker volume option can only be chosen when nothing is playing on the player, or the disc tray is empty, You also have to be in either, Ipod mode or DVD mode to access this menu.
Hope this solves your problem, and i apologize on the delay of this solution ^_^
Oct 25, 2008 | Yamaha DVX-C310SL System
Blue-ray disc problem....jumpy screen
Yes take it back. trading standards would say it's not fir for purpose. Mine is a few years old and plays both dvds and blu ray perfectly
Apr 13, 2017 | Sony Playstation 3 (PS3) Console
AAD C10 Subwoofer Logo
357 people viewed this question
Top AAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an AAD Audio Player and Recorder Expert? Answer questions, earn points and help others
