Question about Kenwood KDC-MP4028 CD Player
Car cd player
Im trying to find which are the speaker wires coming out of a ford galaxy dashboard on 1998 model ive gotĀ  three cables poking out, ican get live and earth but no sound can you help please
    Problem Solver:
  • 20 Answers
Re: car cd player - Kenwood KDC-MP4028 CD Player Car Audio Receivers
Do you have a amp connected
Posted on Jul 12, 2008
0 characters
3 Points
I just got my Pioneer DEH-7200HD Head Unit. The problem is that it doesn't come on when I hook it up. I've tried everything. even touching the ground and positive wires to a 12volt source and still...
This should be the wiring information: 1998 Saturn SL Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6 1/2" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue If you have additional wires, I would see how much voltage is running through them.
Apr 12, 2011 | Pioneer DEH-P7200HD Car CD Player
im install cd player for my car, but not sound came out at all. removed it out, try check for connection, but everything was fine. then i did try play around for speaker 's wire speaker. i saw blue ( power ant) just connect to nowhere. then used blue wire to connect for output speaker, then sound show up. but rerarely to heard. cuz sond was too low. even volume was max. i thought maybe they need for more ground to run out put, or sound chip 40 legs is gone. ( need to replace for it?
Feb 13, 2011 | Xtreme Sound WMS336 CD Player
I have the same model cd player (jvc kd-s575) and I need to connect this straight to a 12v battery. What is the best way to do ths and what wires are positive and negative?
im bit confused, if you are going to use this radio in car, or outside, using car battery.....? anyway, this how you hookup all the wires..
if you are using outside the car using car battery, then you can twist yellow and red togather..for postive 12v+
Oct 26, 2009 | JVC KD-S570 CD Player
I need to hook up cd player
something i found today on google. hope it helps.
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
May 09, 2009 | Sony CDX-CA400 CD Player
Audio sound
the only thing ive seen that would cause this problem would be
a:a dead short on the wire
b:speakers are connected wrong, ie: + to - or - to +
if neither of these is the issue check your speakers to be shure they are not blown and shorted on the inside.
if they are fine then try returning the unit its probably defective
Apr 14, 2008 | Kenwood KDC-MP235 CD Player
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 22, 2008 | Car Audio Receivers
Car stereo
u might have a wired mixed with the power cable for the headlight
Feb 04, 2008 | Kenwood KDC-MP7028 CD Player
Car radio harness diagram
i don't know where to find the power wire for my cd player can yall help me i drive a 97 gms serria
Jan 26, 2008 | Car Audio Receivers
1996 Chevrolet Tahoe
Exactly a minute after you turned it on it went out, did it go out with like a bang or spark, seriously, this would indicate that the wiring wasn't correct somehow, i know u checked the fuse for the correct ampperage required and the most important question do you have an amp because most aftermarket head units aren't wired for 6 speakers,unlike oem Bose unit which has a built in amp and 6 wires output, you should have rca jacks which requires a amp for the additional output speakers. I could be wrong regrding how many output available on your new head unit.
Oct 31, 2007 | JVC KD-G110 CD Player
Kenwood KDC-MP4028 CD Player Logo
89 people viewed this question
Top Kenwood Car Audio Receivers Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio Receiver Expert? Answer questions, earn points and help others
