Question about Kenmore 27841
Kenmore Wahing Machine model 92598200
I fixed the agitator Clutch on my machine and that didn't solve my problem so I disasimbled the machine and took the motor, clutch, shaft to the supply house and found the drive coupling was my problem and that I didn't need to take the whole thing apart. I put it all back together and had no left over parts and everything works; agitation, and spining but the tub is out of balance or I got something back together wrong. I need a schematic of the tub asemble to the frame....and I don't want to spend 59 dollars for manuals....Can you help me?
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 90 tub spins excessively clockwise during wash cycle.
Improperly installed thrust bearing kit. Too many washers cause the basket to spin during agitation.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 04, 2010
Testimonial: "Where is the "thrust bearing kit" and how can it be installed properly?"
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Washing Machine Agitator
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Kenmore Direct Drive washing machine - stopped agitating but still spins and drains,
Have you tried replacing the agitator hub?
That could solve your problem
<a href="https://samedayappliancerepair.ca/">Appliance Repair North York</a>
Apr 14, 2018 | Kenmore Washing Machines
Agitator spin freely is this a clutch problem? i took the trans apart a plastic inner gear "interlock" under the agitator spindel that sticks or is unable to slip back into the engaged mode no broken...
I'm not sure what the actual problem is but...
If this is a basic Sears / Kenmore top load, direct drive machine, there is a set of plastic "agitate cams" that raise when the machine goes into spin mode to "release the agitator"
We had a problem with ours and found that replacing the cams fixed it.
For a better idea of how the transmission works, and a detailed description of the parts see the following Whirlpool documents.
They should help.WHIRLPOOL PARTS SITE
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Oct 19, 2010 | Kenmore Washing Machines
My wahing machine (Kenmore 90 series, toploading) won't go past the agitate cycle.
After agitate - the next cycle is drain.
Nothing would prevent this from happening in the logic sequence except a faulty timer.
Sears website or repairclinic.com will have the timer when you enter the full model number.
Feb 16, 2010 | Kenmore Washing Machines
Kenmore Model 110-24632300 filled up with water and now will not agitate or drain.
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Jan 03, 2010 | Kenmore 22642 Top Load Washer
Rubbing noise from agitator in top load kenmore washing machine
I can't find your model number on the Sears Parts Site:
http://www.searspartsdirect.com/partsdirect/index.action
However.
If this is a basic top load, direct drive, Neutral Drain washer, the problem could point to the transmission "Agitate Cams".
See the following Whirlpool / Kenmore Service Manual for these washers.
The agitate cams are used to raise the agitate gear above the connecting rack during the spin cycle.
Following is a Whirlpool parts list for commercial versions of these washers although the consumer model uses the same part numbers.
See part # 62580 (About $15.00)
I had the same problem with gear grinding and this solved it.
See the following for how to pull the transmission. You don't have to remove the tub!!
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=962131af4fd992034867327e32162166
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds like a complicated job but it really isn't and certainly less expensive that a $170 transmission.
Nov 15, 2009 | Kenmore Washing Machines
WONT AGITATE OR SPIN
check the belt that spins the tub, you will find it at the bottom of the machine, check if its intact.
plz do not forget to vote if i solved your problem
Sep 05, 2009 | Kenmore 24902 Top Load Washer
Kenmore Wahing Machine Motor Overheating
...same problem here. any answers?
May 02, 2008 | Washing Machines
Kenmore washing machine out of balance when spinning, bangs and grinds, when still drum out of balance can be viewed out of balance. Wahing machine heavy duty model C1184514080
Sounds to me like you have a worn drive block and possibly a bad spin tube. The drive block can be accessed by removing the agitator first. Next you will need to remove the spanner nut. Now you can remove the basket. Attached you will see the picture of the drive block, I hope if it downloads. The spin tube locks into this drive block with two tabs that fit in respective grooves in the block. If the tabs are worn off the spin tube, that will have to be replaced as well. Good luck,
May 17, 2006 | Kenmore 24872 Top Load Washer
Kenmore 27841 Logo
73 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
