Question about Hotpoint HTS16HBR Top Freezer Refrigerator
Water collecting in bottom of refrig Hotpoint
Water collecting in bottom of refrig Hotpoint model # CTX21DIBRRWW
  • Anonymous Mar 17, 2014
    water keep filling up in the bottom of refrig
    Sergeant:
    Champion:
  • 214 Answers
Please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
Posted on May 14, 2009
Water is leaking and collecting in the shallow pan below the fruit/vegetable drawers at bottom. I think the water is leaking from the freezer or around the control box on the back upper wall of the refrig...
You are having a problem with the auto defrost system. You need to look around the control box to see if you can locate the drain and clean it out. Sometimes you need to move the refrig. out from the wall and look to see if you can get to the drain that way.Hope you found this helpful and thank you for using Fix ya
Jun 19, 2011 | Hotpoint Refrigerators
My Refrig is collecting water in the bottom. My freezer is on top and the refrig is on the bottom. Water collects in or under the produce trays. What could be wrong
Without a model number or even a brand, this advise can only be general. You have a blocked defrost drain. Each time the refrigerator does an automatic defrost, the resulting melted frost needs to go down to a drain pain near the compressor, where it will evaporate. If the path to the drain pan is blocked, the water has to go somewhere, in your case, down the inside of the liner of the refrig and to the lowest level, under the produce trays. There may be a tube down the outside of the refrig on back which can be removed for cleaning, or the blockage may only be accessable from the area right by the cooling coils inside the freezer section. (usually located behind the back wall, but sometimes under the freezer section floor) You may find that flushing the drain tube using a turkey baster with warm water will be all that it takes to solve your problem.
Jul 14, 2010 | Refrigerators
GE Refridge #tbx21jablraa Water collecting in
The defrost drain tube is plugged. Move the refrig out from the wall and remove the tube which goes from the center middle of the back to the bottom part of the refrig. Clean out the tube and check the part that goes into the refrig. That part usually comes off with a quarter turn or so, then pull.
Sep 24, 2009 | Refrigerators
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Every week or so I get water on the floor around the refrig
there is a pan but your defrost drain tube is stopped up causeing the water to run down in to frig
Mar 30, 2009 | Refrigerators
Model 78182891 Coldspot with excessive water Collecting in Refrig
a plugged or frozen drain is a common problem that occurs from time to time in just about all refrigs so the answer is yes it may occur again in the future. But folllow theses directions and it will probably not occur again for 2-3 years.
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
Post back if you have any questions and I'll gladly help you out Thanks Peyton
Mar 17, 2009 | Kenmore Refrigerators
-water is collecting in bottom of refrig
YOUR FREEZER DRAIN IS CLOGGED AND NEEDS TO BE CLEANED OUT-MIKE
Mar 01, 2009 | Refrigerators
Water collecting at bottom of vegie drawers--water dripping from freezer to refrig
Drain is frozen over, most likely. Defrost the drain completely and verify that the drain is clear. That should fix the problem.
Feb 01, 2009 | Hotpoint HSM25GFRSA
Hotpoint refrig model CTX21EPJR
there is a drain gulley on the back wall with a drain in the middle. this drain is blocked. push something flexible down it and follow up with a small jug of water to make sure it flows away freely
Jul 06, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
381 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
