Question about Elna Sewing Machines
How do I oil a Elna Su Air Electronic Sewing Machine?
I have an old Elna Su that is in good condition. It hasn't been used for years, and I am doing a light sewing project. The needle seems to be getting stuck recently, not in the fabric, but in the bottom of the machine. I'm assuming it needs to be oiled, and the manual says to oil the "red dot" next to the bobbin casing. But is that all I do? And is there any other reason this might happen?
SOURCE: Elna sewing machine, the timing is out.
Hi, Purchased an elna contessa 130. could anyone advise threading procedures , as we do not have a manual with it.......problem with top tension.
Many thanks
Maureen
maureen.reinberger@gmail.com
Posted on Aug 02, 2008
  • 22 Answers
SOURCE: thread jams & wheel axel cannot turn
there are a couple of things that come to mind.
Bobbin:   wound with uneven tension.  Try taking the bobbin, rewind that thread onto another bobbin and wind slowly.  make sure the thread feeds onto the new bobbin evenly.
upper thread:  catching on something or not flowing off the spool easily.
you're doing well, sounds like you consulted the manual and used your noggin, hang in there and let me know if this doesn't help.  we can troubleshoot some more!
Posted on Jan 12, 2009
SOURCE: Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
Posted on Jan 23, 2009
  • 14 Answers
SOURCE: ELNA 7000 SEWING MACHINE
If you bend over the front of the machine, you will see a slider switch on the back of the machine, and there is a small "button" at the bottom right of the switch (your right). If you push this button down, you can slide the slider switch to your right and the feed dogs will go up.
Posted on Mar 26, 2009
Sewtech1
  • 69 Answers
SOURCE: elna su motor won't turn off
it is only your Capasitor that is faulty and can be by passed
Posted on May 01, 2009
Hello. My 30 year old Elna electronic SU doesn't stop after I release the air pedal, from time to time. I have to tap two or three times on the pedal or simply turn off the machine to make it stop. Then,...
Sounds like the air electronic bellows sensor bit inside the machine is faulting, it can be repaired if you can find an old school Elna technician. Mine would do this too, and I did the same as you, worth putting up with as I love my AE SU machine.
if you are technical yourself and you do want to see if you can repair it, I would suggest joining the Yahoo Group called Elna Heirlooms, the members are very good at sharing knowledge on repairing the Swiss made Elna machines and I'm sure Ive read a thread on this fault.
Jul 04, 2014 | Elna 2007 Mechanical Sewing Machine
Manuel elna su air electronic
I have a manual for the SU Air Electronic if you are still looking? you can email me on tallygirl98 at yahoo dot com and I'll send you a scan
Jun 23, 2014 | Elna 2007 Mechanical Sewing Machine
Oiling machine
sewing machine oil,,you should be able to get it at any sewing machine store or hancock fabric.
Jun 22, 2013 | Elna Sewing Machines
I have a Elna SU - new in the mid-70's and recently took it to an auth. repair place. The needle position wheel is very stiff - almost impossible to move. It is used mainly in conjunction w/the...
I was going to direct you to the www.arizonaexpressionz.com website which had lots of Elna instruction and service manuals including the SU but today its links seem to be out of action. It may come back to life so worth checking another time.
In the meantime, did your repair shop actually service the machine or just pull the top cover off, put in oil and tell you that's it. There are still Elna trained technicians out there who are familiar with the older Swiss made machines and its probably worth trying to find one if you think the service centre you've visited hasn't actually addressed the issue.
The other option is if you are in the USA, contacting White Sewing Centre and maybe sending it to them to be serviced. LInk is www.whitesewingcenter.com.
Or if you are technically minded yourself, you could join the "Elna Heirloom" group on Yahoo and then ask the other members there for help, there are lots of Elna lovers with models much older than the SU there who lovingly keep their machines running and share their knowledge. Just be clear as to whether yours is a Star Series SU (white with blue top) or Air Electronic SU (if you look on the id plate of the machine there will be a 2 digit code either 62 or 68.
I hope this helps you a little, I'd certainly persist with it if I was you. I just purchased my second SU 2nd hand after buying a new model of another brand 5 years ago and being quite disappointed with its performance, particularly with heavy jobs.
Aug 07, 2011 | Elna Sewing Machines
I purchased a used Elna su type 62cr209707. I need an instruction manual, where do i find one?
The Star Series SU is a lovely machine,
you can purchase a manual from here - well worth spending the dollars to find out how it works, especially the buttonhole which isn't like modern 4 step ones. You may also find that the foot control has a switch to give you slow speed vs normal speed sewing.
http://www.tradebit.com/filedetail.php/91117786-elna-sp-st-su-sewing-machine-manual
If you are in the USA you could also visit www.whitesewingcenter.com, they have lots of Swiss Elna goodies for sale and are very knowledgable on these machines.
You might also want to track down a newer Swiss made Elna pressure foot holder with the clip on feet, rather than using the full feet with your machine. They are interchangeable. Have you got the black discs to go with your SU too? there is a large range so you can sometimes track down some more to add to your collection.
There is also a newer black pressure foot screw which is a combined thread snip, its a bit bigger in diameter to the black thumb screw on your machine now and you can use it to cut and hold the threads at the end of each seam, very cute.
Always give this machine a good clean and oil before using it, there should be a red dot in the middle of the bobbin holder, oil here regularly and any other points that the manual shows with good quality sewing machine oil, it takes 130/705H standard sewing machine needles, put in a new needle for each project to get great stitching results.
Enjoy your SU!
Apr 15, 2011 | Elna 3210 Mechanical Sewing Machine
Elna Carine Electronic Sewing Machine
You should be able to buy a manual online but it may be a cd or image pdf file. Try www.sewingpartsonline.com or www.sewusa.com. If they don't have the Carina but have the Air Electronic SU, model 68 then this will be almost the same. Main difference is the Carina has the needle up/down button.
Here is threading up images to get you started.
Sep 21, 2008 | Elna 8007
Sewing Machines Logo
475 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
