Question about Dryers
Dryer not heating w/o indication
Dryer was working fine & then all of a sudden quit heating all together. Everything else seemed to be working fine.
    Problem Solver:
  • 9 Answers
It's very possible that you need a new heating coil. This is an easy do-it-yourself fix if it's an electric dryer. Save all your receipts and purchase the replacement part from a business that will give your a refund (minus a small restocking fee perhaps).
Posted on May 14, 2009
How do I run a diagnostic? The dryer just quit heating. Everything else is working fine. How do I trouble shoot to see which part needs replaced?
If there is no heat, you can conclude the heating element has failed or a controller has failed but your description does not identify the dryer brand and indicate whether it is electric or gas.
Dec 26, 2014 | Dryers
GAS dryer will operate, but not heat. No error codes showing
If not heating at all try this. Go to electrical panel box and find the breaker labeled Dryer. It should have 2 joined together levers. Turn it off and see that the dryer is OFF (this verifies you have the right one) Operate this breaker back and forth (on and off) at least ten times. Then put it in the ON position and try dryer again. If it works you have a bad (intermittent) circuit breaker. Get an electrical handyman to change the breaker. If changing the breaker does not fix it you may need an appliance repair person. Why this is. The cycling on and off of the heat at the dryer is rough on circuit breakers. If this dryer has been in place for some years and replaced another dryer it is probable that the circuit breaker was not changed. BTW the dryer functions (except heat) operate from one side of that 2 sided breaker, while the HEAT operates from both sides at HIGH current.
Mar 23, 2014 | Frigidaire GLEQ642A Electric Dryer
Dryer quit heating suddenly.
The fuse is located on the blower housing and if it was blown the dryer would not run at all. The limits is mounted on the heater housing and that could kill the heat as well as a blown heating element. I worked on a similar dryer not long ago with a heating problem and did a video:
DRYER NO HEAT
Jul 08, 2012 | Dryers
Kenmore dryer #86863800 suddenly stopped heating. Having trouble figuring which thermostat or element should be replaced. This dryer has no high/low setting. Only more dry or less dry. One big knob to set...
Hello & Welcome to FixYa
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Kenmore Elite HE4 Electric Dryer
Everything seems to work, but can not get heating element to work
The first thing to check is for a burned thermal fuse. It is about one inch long and is located inside the rear of the dryer and is usually attached to the exhaust duct. It can be tested for continuity using a multimeter. A lack of continuity indicates a blown fuse and it will need to be replaced. Hope this helped and best wishes.
Aug 03, 2009 | Dryers
Old Frigidaire apartment size (24'0 top dryer stopped working.
check the breaker i know the washer works so how come the dryer works on 220volts if one side is out the washer will work but not the dryer if that is not it check the door switch the unit also has a thermal fuse that could be out there is no reset button
Nov 30, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryers Logo
78 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
