Question about Compaq ProLiant 5500 Server
Proliant 5500, installed configuration and OS w2k3 all operationa
... cannot "see" the onboard or the card controller from BIOS or through ACU. any thoughts? Also, this computer is 10 years old and I have had it since 2002, new and this is the first time I have fired it up.
2 proc 550 operational
10 HDD 72.8 accessible and show up as assignet to controller in bios
no other anomolies
any help is appreciated!
    Sergeant:
    Champion:
  • 208 Answers
What controller do you have? Have you tried running smart start that came with the system?
Posted on Sep 03, 2009
How to boot from CD
Do you have smart start installed on it? If so:
The F10 "Bios" partition is only available if the server has had SmartStart installed on it. The SmartStart partition is actually a 20Mb (ish) partition on the configured hard disks. If the partition is available, you will be prompted to press F10 at the end of Post boot just before the OS would kick in.
The position of the drives is important so keep them in 0,1,2 & 3. Once you can boot off SmartStart (v5.50 as mentioned), you can reconfigure the Array config in the Array Configuration Utility (ACU).
Jul 30, 2014 | HP Compaq ProLiant ML530 Server
It's posible to install windows 2003 server on hp 2210b
Change SATA Native mode in BIOS & use W2K3 Ent Edn with Sp1
Sep 12, 2011 | HP Compaq ProLiant ML370 G3 Server
I have ML350 G3 Server SA 532 and 2 HDD SCSI, W2K. I want intall RAID 1 Can I help me???
unable to understand your question.
If you want to configure raid 1 and install OS freshly then follow these steps.
1) make ready all the required h/w.
2) Swith on the server.
3) when post starts reading SA532 controller press F8 button .
4) you will enter into Raid card bios.
5) select View to know any existing logical drive.
6) select Create logical drive,select both hdd's by pressing space bar.
7) press F8 to confirm changes,save and exit.
8) Enter into bios and set the boot controller order smart array controller as 1st.
9) press escape button and restart the server.
10) boot with cdrom and proceed for os installation.
6)
Jan 19, 2011 | HP Compaq ProLiant ML350 G3 Server
Ths screen displays ERROR,Expansion ROM not initialized-PCI network controller on Motherboard. Bus:04,Device:04,Function:00 how do i fix this? I am trying to install win 2003 server ,system not...
The ProLiant ML110 server with System BIOS Version 16 supports a total of eight IPL devices. Four IPL devices, such as the IDE controller and the floppy controller, are integrated, leaving support for four additional PCI IPL devices (i.e., PCI card plugged into PCI expansion slots); however, the ProLiant ML110 has five PCI expansion slots. Therefore, it is possible to configure the ProLiant ML110 with five PCI IPL devices (such as SCSI controllers or NICs) and exceed the limitation of System BIOS Version 16
The resolution to the problem is to update the System BIOS Version 17 which supports a total of nine IPL devices and five PCI IPL devices. Update the ProLiant ML110 server to System BIOS Version 17
i could not include the url for the download because you did not especify the generation of your server
but follow this link
1.select your server with the corresponding generation
2. select the operating system
3. from the download list select the bios update to a bootable usb or diskete
4.install the os
Oct 27, 2010 | HP ProLiant ML110 Server
ERROR: Expansion ROM is not initialized- PCI network controller on Motherboard. Bus:04, Device: 04, Function : 00 Secondly i have been trying to install win server 2003 on it, but i cannot seem to get...
i could not include the url for the download because you did not specify the generation of your server
4.install the os
I want to install a new scsi but when my os windows small business server 2003 it gives me "setup either detected multiple disk in your machine that are indistinguishable or detected raw disk(s). Setup has...
using the ACU (array configuration utility) create a raid 0 with this drive after the hard drive is being formatted and is configured as raid 0 (no redundant) restart the server and the hard drive should be detected as a new logical volume with a assigned letter "D" "E"
ACU
Jul 30, 2010 | HP ProLiant ML370 G3 Server
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
I need driver hp proliant to install
If you are installing an OS from scratch, download the Proliant SmartStart CD for your server from HP. You simply boot from this CD and follow the instuctions to load your OS. Smartstart will configure your drives, pre-load drivers, and gracefully pass control over to the OS installer.
Jun 09, 2009 | HP ProLiant ML110 Server
Compaq ProLiant 5500 Server Logo
319 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
