Question about Dishwashers
Drain problems I have a Kenmore 665.17292992 portable dishwasher. I've changed the filter and the seals however it still does not want to drain. It will drain but extremely slowly and since it's on a timer, it only drains maybe 10% of the water out. My next step was/is going to be the Check Valve... but I am at a loss right now. I thought for sure it would be the filter. Any advice would be appreciated. Thanks, PM
  • scubaphillip May 14, 2009
    Howdy,
    Not 5 minutes ago I fixed it.. FINALLY.. after 3 months of no dishwasher.
    It was in fact the Check Valve... it had two items lodged perfectly in it..
    Thanks for the help though, I truely appreciated all input.
    Problem Solver:
  • 9 Answers
This may not be the solution, but look for an air in-take somewhere on the top/back of the unit. It's probably covered by a stainless steel cover that can be taken off. Unscrew this cover and see if the air intake is blocked with lint. This is usually the cause of dishwahers (whether portable or built-in) failing to drain.
Posted on May 14, 2009
Water not draining completely.
Clean the drain filters: click on filters
Jan 24, 2013 | Kenmore Dishwashers
Kenmore 15652 model. won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
Apr 22, 2011 | Kenmore 24 in. 15652 Built-in Dishwasher
Where can I find an online trouble shooting guide or owners manual for my Kenmore dishwasher 36314489100? It will not drain.
Hi
You can download the manual from this link--
Kenmore dishwasher 36314489100 User Manual
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Mar 20, 2011 | Kenmore Dishwashers
My portable GE dishwasher is clogged and wont drain
Hi
Feb 13, 2011 | GE Profile 24 in. Built-In Dishwasher...
Kenmore dishwasher 15522000 will not drain at end of cycle I took off front lower panel removed clamp at drain and water is barely dripping
Hi
Daniel
Jan 07, 2011 | Kenmore Dishwashers
Standing water in dishwasher
Hi
Oct 19, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher not cleaning - want to clean drain
We have a Kenmore 665.17702k600 Portable dishwasher with a similar problem. What we did was pop off the drain cover (turns out the one screw wasn't doing anything and just pushed down into the unit when screwdriver was applied). We popped it off by shimmying a screwdriver under the panel, and applying torque on the long end. It just popped right off. Then there was this nasty stale water, and not much obvious debri. We used a wet vac to slurp all that up. So that's the solution we took -- haven't tried it yet, so not sure if it will actually fix the problem...
Nov 02, 2009 | Kenmore Dishwashers
Kenmore portable dishwasher won't drain model # 665 17799990
Service person said is is not supposed to drain all the way. Something about it helps something not dry out.
Jun 24, 2009 | Kenmore Dishwashers
Kenmore portable dishwasher not working
is the buzz sound when you ask it to drain or ask it to fill with water? or is the buzz sound when it is trying to wash? IF it is when you ask it to drain either you have something stuck in your air gap causeing no drain or there is something in your pump I would check the easy stuff first by checking the air gap this is if it is buzzing when you ask it to drain. let me know what is the senario.
May 29, 2009 | Kenmore 17252 Free-standing Dishwasher
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
Owen Barnes
