Ou need to check the resistance of the sensor at the control board.
Unplug the oven, open the control panel and locate plug J3 at the control board.
Disconnect the plug and check the resistance between two white wires. The meter set for 10 kohm.
At the room temperature the resistance should be around 1100 ohm.
Check the wire harness between the sensor and the control board.
Only then if everything check out fine - replace the control board.
Here is the part to order.
