Question about Kodak EASYSHARE M1063 Digital Camera
Blown sand in camera, blew out as much as i could.
Got blown sand in camera, blew out as much as i could. camera turns on then turns off. now it won't turn on at all. changed battery on it as well. did not solve problem. the camera is a kodak easy share mx 1063
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
You got to really clean it good. Probably the sand is in the lens extension preventing the lens to oppen. That is the problem.
Vitally
Posted on May 15, 2009
1992 geo prizm - radiator hose broke and replaced, but car won't start now - ideas?
you said it cranks then you said it wont turn over if it wont turn over you might have get the engine to hot and seized the engine please spesifiy if the engine turns over or not
Jun 09, 2012 | 1992 Geo Prizm
Camera will not turn ON. I changed the batteries but still no change.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 24, 2011 | Kodak EasyShare M530 Digital Camera
Hi, my Kodak easyshare MD41 will turn on but when i do it retracts the lens right away. i took it to the beach, so im guessing sand or the sand dust got in it. Is there a way i can fix this without having...
You are right it got some sand into its eyes. You know that canned Air you can get at the office supply stores I used it to blow out the sand. Remember it will blow refrigerant out if you shake it, or turn it upside down. I set it on a table so I could blow straight at it instead of down on it and I blew it off, then blew it off while I tried to open it then opend it and took out the battery to keep it open and blew it evry where i could immagine air might go and put the battery back in and :-)
Feb 20, 2011 | Kodak EasyShare One Digital Camera
Sand got in camera and lens will not stay extended keeps turning on and extending and then going back into camera.
Sounds weird but I put my mouth around the lens and gently blew into it to loosen up any sand or dirt. Then I would try to **** as hard possible to get it out. Strange, I know, and you do get some sand in your mouth, but it worked for me after a few times.
Sep 20, 2010 | Nikon Coolpix S210 Digital Camera Plum ...
I have a Nikon s220 coolpix and everytime I turn on the camera the lens opens, makes a strange noise and closes - it does this 3 times and then I get a lens error message on the screen. Do you know what is...
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jul 02, 2010 | Cameras
My camera freezes when i turn it on or off and does not work properly. it could have something to do with the batteries, it came with mitsubishi batteries and has not worked since they went dead and i...
Those are symptoms of both low batteries and a fualty lens unit - when you turn the camera on, it does a self test and if it fails, the camera turns off or locks up. Common failures are sand in the lens. BUT try good batteries first.
Jun 08, 2010 | Olympus FE-310 Digital Camera
My kodak easy share m1033 camera turns off when i press any button
there is dirt or sand in motorized lens turn camera on and pop battery out before lens goes back in. Use a lens cleaning cloth and wipe all the outside of the camera lens well I also use a can of air and blew the three rings of the lens.I had to do this two times but now the camera works great
Mar 23, 2010 | Kodak EasyShare M1033 Digital Camera
Problem with M340 Kodak easy share digital camera..( automaticall
I had the same problem after a day at the beach. What I did was get a can of compressed air (from the computer section) and blow air around the lens as I repeatedly turned it on. It took about five cycles, but I eventually cleared whatever was preventing the lens from fully opening.
Good luck.
Aug 17, 2009 | Kodak EASYSHARE M1063 Digital Camera
Canon lens cover won't open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 09, 2009 | Canon PowerShot A630 Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
152 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
