Question about Canon PowerShot A570 IS Digital Camera
Why is it telling me my card is locked?
When i turn on my camera it tells me that the card is locked and i dont know why. and when i try to take pictures it doesnt work at all.
    Sergeant:
  • 246 Answers
There is switch on your SD memory card, try to put it on unlock position. If it doesn't solve the problem, you may need to open the camera and check the SD card slot. Refer this solution:
http://www.fixya.com/support/t2234315-its_saying_memory_card_locked_its_not
Posted on May 23, 2009
2 Suggested Answers
  • 3289 Answers
SOURCE: My camera is telling me the card is locked. It
Remove the memory card from the camera if it isn't already, and look along the left edge of the card. Find a small tab and slide it forward (to the unlock position) and carefully slip the card back into the camera and try again. If it reports locked again, carefully remove the card to see if the tab has moved back to the locked position.
If the tab is moving to the locked position during the insertion process, you could place a small amount of tape along the card edge - over the tab - and carefully insert the card again. You might have to remove some tape to allow the card to fit into to slot. If you never lock the card - you could put a very small drop of super glue on the tab to hold it in place. Wait for the glue to set completely before inserting into the camera.
I hope this helps!
Posted on Nov 10, 2009
Testimonial: "Thank you so very much....It works now. You're a very smart man. Thanks again. Jan"
Hi can you please tell me how to turn off the card protected feature? i dont even know how i turned it on.
i think you need to access the card protect feature on the memory card and try to flip it in the other direction. Maybe u might have mistakenly turned the card protection on.
Feb 26, 2011 | Polaroid i835 Digital Camera
Its telling me memory card is protected { reset switch on memory card} go to review. I dont know what to do.... Please Help me.
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Nov 23, 2010 | Kodak Easyshare CD80 Digital Camera
When i turn on my camera and i want to take a picture it does'nt let me. it says "this card is lock" and i dont know how to unlock it.
SD cards have a little notch on one side with a yellow tab. This tab can be pushed one way to "lock" the card (so no data can be written to it) or pushed the other way to "unlock" it.
There should be an arrow next to the notch telling you which way is which, but if it's locked right now, push the tab the other way and insert the card again, and it should work fine.
Jun 30, 2010 | SanDisk 2GB microSD Memory Card
Camera says card is locked but it's not!!!
You already know about the 'lock' switch on SD cards; did you know it doesnt actually lock the SD card by itself? It merely pushes a switch lever in the reader (in this case, your camera), that in turn tells the electronics to NOT write on the SD card.
So, if your SD cards are indeed working (check on a card reader), it would look like the lever in the camera that senses the position of the lock switch is jammed / bent. If you could pry into the card slot in the camera, and try to shake this lever with a long narrow object (a straightened paper clip, perhaps), that might yield good results.
Alternately, look up 'CHDK' on Google; it is an alternate OS that gives your Canon *lots* of other features. In your case, more importantly, it *requires* the SD card to be locked in use. Dont worry, with CHDK booted in, the camera will store pictures even when it sesnses the card is write-protected. So, it not only solves your problem, it gives you loads of extra features like RAW capability, time laps, remote operation and more, all for free.
Regards,
Anand Dhuru
Apr 21, 2010 | Canon PowerShot A710 IS Digital Camera
Dont know how too put it in the camera
please tell us about your camera make/model?
Apr 03, 2010 | PNY 2GB microSD Memory Card
My memory card says it is locked. i have no clue how it happend. I dont know how to get it unlocked. Can you please tell me what to do?
Hello.If you hold the card faceing you there is a small slide button on the upper left edge which locks and unlocks the card.
builderdale
Jan 15, 2010 | HP Photosmart R725 Digital Camera
My camera has a memory card locked label on it telling me to switch it to write. What do I do?
on most sd cards, there is a switch that can lock the sd card so you cant put files on or take them off. chech to make sure that you dont have it on lock
Oct 30, 2009 | Nikon D40x Digital Camera
Unlocking a vidoe or picture
download all your files to the computer and format the card through the camera menus (not the computer)
Sep 01, 2008 | Olympus FE-210 Digital Camera
How to unlock memory card
in your memory card there is a very small button adjustment that can be use to unlock and lock your memory. try moving it
Jul 09, 2008 | Canon PowerShot G7 Digital Camera
Canon PowerShot A570 IS Digital Camera Logo
222 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
