Question about HP vs17
Last month screen completely filled with gray and white stripes running from top right to bottom left. Turned off, and restarted. This happens several times weekly, whether on internet or not, using Windows word, or another program. Seems to be random, many days it runs from early a.m. til late at night with no problem. Sometimes turning it back on, it immediately repeats stripes, sometimes not. (Yesterday it was a lovely green and white). This problem began after we got a new motherboard, which included a video card, installed at shop where unit was originally purchased.
  • 91 Answers
That is most likely the wrong video card for that motherboard. Or the video card slot on that motherboard is faulty... I would recommend taking it back to the shop and letting them fix it, since this happened after you got it back from the shop...
Posted on May 14, 2009
  • AJ Jones
    AJ Jones May 14, 2009
  • AJ Jones
Need scosche manual ha028
  • Yellow - 12V Constant
  • Red - 12V Accessory
  • Black - Ground
  • Blue - Power Antenna
  • Orange - Dash Light Dimmer/Illumination
  • Green - Left Rear Speaker (+)
  • Green with Black Stripe Left Rear Speaker (-)
  • White - Left Front Speaker (+)
  • White with Black Stripe - Left Front Speaker (-)
  • Purple - Right Rear Speaker (+)
  • Purple with Black Stripe - Right Rear Speaker (-)
  • Gray - Right Front Speaker (+)
  • Gray with Black Stripe - Right Front Speaker (-)
Mar 13, 2013 | Car Audio & Video
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
I need to know wat colours do wat on a kenwood KVT-739 car Stereo DVD player wiring
yellow - constant power, red - switched or ignition power black - ground white - left front speaker pos. white/black stripe - left front speaker neg gray - right front spkr pos gray/black stripe right front spkr neg green - left rear spkr pos green/black stripe - left rear spkr neg purple - right rear spkr pos purple/black stripe - right rear spkr neg blue - power antenna remote blue/white stripe - amplifer remote turn on
Aug 16, 2010 | Kenwood Car Audio & Video
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
(Gray Plug)
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
Need wiring diagram for sony cdx-gt200
blue\white stripped= amp remote
black= ground
blue= ant
red=positive
yelow=positive 12v
white=left +
white\black striped= left -
gray= right +
gray\black striped= right -
green=left rear +
green\black striped=left right -
purple=leftr rear +
purple\black striped=right rear -
Jul 18, 2009 | Sony Car Audio & Video
What do the wiring colours mean?
This is the typical configuration for the wires coming from a car stereo.
Right Rear Spkr (-) = Purple w/ Black Stripe Left Rear Spkr (-) = Green w/ Black Stripe Right Front Spkr (+) = Purple Gray Left Front Spkr (+) = Dark Green White Right Rear Spkr (+) = Blue w/ Orange Stripe Purple Left Rear Spkr (+) = Brown w/ Blue Stripe Green Power Antenna/Amp = Blue +12 Volt Battery Wire = Yellow +12 Volt Ignition Wire = Red Right Front Spkr (-) = Gray w/ Black Stripe Left Front Spkr (-) = White w/ Black Stripe
Jul 07, 2009 | Car Audio & Video
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
My wife bought a kenwood z828/uf4. there are wires in the back but none of them are labeled. can anybody help me
red - 12v ignition
yellow - memory 12v cont.battery
orange - illumination
black - ground
white- front right speaker +
white/black stripe - front right speaker -
gray - front left speaker +
gray/black stripe - front left speaker -
violet - rear right speaker +
violet/black stripe - rear right speaker -
green - rear left speaker +
green/black stripe - rear left speaker -
blue - remote, amp
blue/white stripe - power antenna
if you don't have a blue/white strip wire than the solid blue wire goes to power antenna, amp and remote...........
hope this helped you
Feb 26, 2009 | Kenwood Car Audio & Video
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Wireing dia for cdx l400x
if your wires are white\w blk stripe gray\w blk stripe green\w blk stripe purple\w blk stripe the white and gray is front's green and purple are rear's white is right gray is left green is left purple's right
Dec 14, 2008 | Car Audio & Video
HP vs17 Logo
67 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
