Question about Zebra Z4M Printer
Zebra z4m cuts part of the label off
When we go to print tags, some of them will print normal but either at the beginning or the end of a run it will cut off half of the label including the barcode. Is there some kind of adjustment that we can make to prevent this? We have tried everything we could think of with no luck.
  • Anonymous May 25, 2009
    I am also using a Zebra Z4M printer. When i am printing the labels, the last character of the wording got trimmed off/cut off almost 50% of the character. The weird thing is it only happened for the last character!
  • Jim Reder
    Jim Reder May 11, 2010
    What software do you use?
  • 45 Answers
SOURCE: Zebra TLP2844 does not print the barcode label
Turn off the printer, then hold down the feed button while you turn it on again. After the configuration label prints, turn the printer off and on again,then try to print your labels.
If the barcodes still don't print, make sure they don't extand past the top, bottom or side of the label. If you software allows you to "clear the label cache" or "re-image the enitre label", try that.
Posted on Sep 23, 2008
  • 6 Answers
SOURCE: Zebra label alignment
you can adjust this in the template file for your price tags. how did you create your basic price tag label? in the zebra label creator? if so, make the adjustment there. if you have a .ejf file for your price tag label, you should be able to open it in notepad and add the height in pixel dots with the "q" or "Q" command from the EPL programming handbook. This can be a little tricky, but with some trial and error, you can get it.
EPL2 programming guide:
http://www.zebra.com/id/zebra/na/en/documentlibrary/manuals/en/epl2_manual__en_.DownloadFile.File.tmp/14245L-001rA_EPL_PG.pdf?dvar1=Manual&dvar2=EPL2%20Programmers%20Manual%20(en)&dvar3=2746e
Posted on Apr 28, 2009
RoryMRP
  • 111 Answers
SOURCE: Zebra M4 is printing blank labels
Did you switch your ribbon as well?
Posted on Jul 07, 2009
seltzercool
  • 21 Answers
SOURCE: How to change the printhead on a Zebra z4m barcode
u can do it yourself. u just need a screwdriver to do that, loose the scew on the top of the head, the plug off the cable from the head
Posted on Aug 20, 2009
  • 13 Answers
SOURCE: Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Posted on Sep 07, 2009
How do I set up Zebra Z4m to print Adobe Forms Label?
If it's in pdf, then just print it with the printer driver
Dec 11, 2014 | Zebra Z4M Printer
Delay in printing labels with Zebra Z4M
Set in the driver the size of the label and print mode to Tear off.
Roberto Martinez
Jul 22, 2009 | Zebra Z4M Printer
Jul 06, 2009 | Zebra Z4M Printer
Zebra Z4M only feeds a small portion of the label.
You should try a factory reset. Power off the printer. Hold the "pause" and "feed" buttons down while powering up. Allthe lights will blink and when they stop blinking, release the "pause" and "feed" buttons. This will factory reset the printer.
Apr 24, 2009 | Zebra Z4M Printer
Can't print images on zebra z4m printer
Check the "Dithering" setting in the printer driver. Turning "Dithering" on improves graphics but reduces speed of processing.
Apr 07, 2009 | Zebra Z4M Printer
Slow Printing on Zebra Z4M
An unorthodox solution is to install an old driver. Another solution is to use with Codesoft the driver from www.seagullscientific.com, and with Zebra Designer, the Zebra Designer driver. If the printer is connected to the serial port, speeds up communication.
Roberto Martinez
Mar 30, 2009 | Zebra Z4M Printer
Zebra Z4M Communication
Yasemin, the most practical solution is to design your label on a software like a label matrix or zebra designer and print to a file and have the ZPL codes. Roberto Martinez Mexico bartech9@yahoo.com.mx
Feb 27, 2009 | Zebra Z4M Printer
Inconsistent printing.
The sensor tag is not well calibrated, press FEED, PAUSE and CANCEL, turn on the printer and release the keys when you move the label to print and let the end be calibrated.
Roberto Martinez
Mexico
Oct 03, 2008 | Zebra Z4M Printer
ZEBRA Z4M PRINT QUE ERROR
Try a reset: press the PAUSE and FEED keys while turning the printer, release the keys when feed the label. You can also try downloading the latest firmware.
Jul 02, 2008 | Zebra Z4M Printer
Zebra Z4M Plus
this is a color printer or not
Oct 01, 2007 | Zebra Z6M Plus Thermal Label Printer
Zebra Z4M Printer Logo
139 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
