Question about Dell Dimension 1100 PC Desktop
Can't start windows after power failure
After power failure . Message on monitor suggests starting windows by clicking on START WINDOWS NORMALLY. no respnse with mouse of clicing enter
  • 30 Answers
You must first check if the keyboard and mouse is properly inserted on the back of your cpu. or if you are using laptop you must forcely restart the system.
Posted on May 15, 2009
My tool improper shut down detected checking file system please help me
that message appears if the shut down process is not followed.
power failure , emergency shut down or other problems that just shut the pc down will result in files and folders becoming corrupted and not saved
when booting up if the message appears that states start in safe mode , start normally etc , click on start normally
Oct 25, 2016 | Computers & Internet
My optiplex 320 is making two high pitched beeps on starting boot, also im not getting anything on the monitor
James,
It sounds like the refresh rate is set to high. Since you do not mention what OS is installed I have listed information on how to change in Windows,XP.
Start the computer and press the F8 key. Choose Safe Mode. Once the system gets into Windows follow the steps below and then restart the computer. If this does not resolve your issue email me at my email address below and include your OS information.
How to Change the Screen Refresh Rate of Your Monitor
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Or your system is giving off a beep code in which case the beeps come in a 3 beep sequence. Below is the beep codes and what each represents.Beep Codes
Troubleshooting steps and more information about the OptiPlex 320 beep codes Beep Codes Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3-1 through 2-4-4 DIMMs not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller Test failure 3-3-1 NVRAM power loss 3-3-2 NVRAM configuration 3-3-4 Video Memory Test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No time tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math coprocessor test failure 4-4-4 Cache test failure
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email jesse_leonard@dell.com
Sep 18, 2013 | Dell Computers & Internet
Monitor has no picture, repeatedly tries to cycle ON but can't
sounds like power board failure. You can disconect power lead for 30 minutes and try again but it does sound like end of life
Feb 04, 2018 | NEC Mitsubishi Diamond Pro 2040u NF...
While installing windows Xp it says no hard drive found but displays in BIOS
Sounds to me like your harddrive needs a driver for windows to recognize it. You could try this harddrive utility.
Jan 10, 2011 | Seagate (AU-80GBSATAHD) 160 GB SATA Hard...
Hi, my Dell Vostro 200 monitor isn't working; when I boot up the light is blue and everything else seems to work but the monitor says 'Entering power save mode' or something and it shuts off. I can't get...
Your monitor is most likely fine. That message is the monitor telling you it's not getting any video signal from the computer.
If you're hearing all the sounds that go with a normal startup (usually a beep from the motherboard, then hard drive activity, finally the normal Windows startup sound through the speakers), and seeing that message, then you may have a monitor problem. You can try another monitor as a test.
The trouble is probably that the computer is turning on, but not actually starting up. This may be due to power supply, memory, processor or motherboard problems. Or one of the drives or expansion cards connected to the motherboard may be keeping the system from starting.
Make sure the memory modules are firmly seated in their sockets, and disconnect everything else but the power supply. If the motherboard, processor and memory are working, the system will start and you'll see something on the monitor. Then you can start reconnecting parts and see when the problem returns.
Mar 30, 2010 | Dell Vostro 200 Mini Tower With 20" Flat...
Signal has gone
If the monitor comes on and displays a message like "no input signal" or something similar, it's working properly but there is nothing coming from the computer. People often think that the computer is working and the monitor is at fault, when in fact the computer isn't starting up.
When you turn on the computer, do you hear the normal sounds of the power supply fan running and the hard drive spinning? Most computers will give a beep when they turn on and the motherboard finishes some startup checks. Do you hear that? Do you ever hear the normal startup sounds that mean Windows is actually running?
If you are convinced the computer is starting and booting into Windows, I would suggest you borrow a known good monitor to use as a test. If it works, that obviously means yours is bad. In most cases there's nothing you can do to repair a monitor yourself beyond checking for loose connections, bent pins in the signal cable plug, or a damaged cable.
If a known good monitor still has no image, the computer is at fault. Either the video card or integrated video isn't working, or the computer isn't actually starting up. In any case, that's where you would need to start looking for the cause.
Hope this helps you along the way to solving the problem. Thanks fo using Fixya!
Feb 02, 2010 | ViewSonic VX2235WM Monitor
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
Emachine 15' lcd monitor
Your query - "can the monitor work with an older HP computer?"
Normally yes, assuming that there is no hardware fault. The message is an indicator that somehow the settings of the display of the old HP computer does not match that of the Emachine 15' LCD monitor.
Perhaps what you can do is to run the old HP PC in Safe Mode (press F8 before Windows starts), using the arrow keys, select top mode setting in the Menu which is Safe Node, hit enter. Windows should then start and normally should be viewable no matter what settings the monitor can handle. On Safe Mode Windows, right click on any clear area of the desktop, click on properties, Settings tab, move the Screen resolution to the left most position, set the color quality to the lowest possible choice. Click on Advanced button, click on Monitor tab, set Screen Refresh Rate to lowest possibler, OK, OK, reboot.
Hope that this be of some help/idea. Pls post back if things worked out or should you need additional information.
Good luck and kind regards
Dec 09, 2007 | E-Machines eMachines Monitor E15T4
Dell Dimension 1100 PC Desktop Logo
61 people viewed this question
Alun Cox
