Question about Maytag PAV2300 Top Load Washer
No cold water to my Maytag Top loading washer
Hot water comes in fine but not the cold. If I fill it with buckets of water it works fine.
    Problem Solver:
  • 9 Answers
Pull the washer out from the wall and disconnect the water lines from the washer. Check to see if a build-up of minerals is clogging the screen on the cold water line where it enters the washing machine.
Posted on May 14, 2009
My washer will not fill with water or do any functions when i turn the dial
My Hoover 7700l ...on "fill" cycle, the water dribbles in. Takes hours to fill so we use buckets to reach the required level.
Tried: Swapping cold and hot water inlet hoses, making sure that dial is in "hot". This solved the problem for filling, BUT when "rinse cycle appoars, it's back to the dribble again.
any ideas?
Jan 23, 2011 | Maytag LSE7806A Top Load Stacked...
We have a Maytag A612 washer. Today it wouldn't fill all the way with cold water (for a cold water load). If I hit the Warm or Hot button, it resumes filling with Hot water, but I don't want Hot so I hit...
Turn off the cold water faucet.
Remove the water hose from the machine and the faucet.
Clean out the filter screen in the washer water valve.
Look in the hose for a secondary screen and clean it also if one if there.
Not all hoses have screens.
All water valves do have screens.
Sep 05, 2010 | Maytag SAV4655A Top Load Washer
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Will fill with cold water but not hot
the hot water inlet valve is shot replace it
Apr 27, 2010 | Maytag Atlantis MAV7551 Top Load Washer
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
Whirlpool Top Loading Washer not filling when set on hot only
check the water inlet valve assembly. Also, this could be a timer issue as well. check the Hot valve block connector on the control panel board. it could be lose or separated or broken. there is a wire that leads to the valve on the hot side as well. check this.
Mar 13, 2009 | Washing Machines
Maytag Legacy Series Top Load Washer model SAV515DAWW When filling, the cold water just trickles in and takes a long, long time to fill. When I unscrew the hose from the washer and turn the water on it...
From what you have said, you may have a bad solenoid in your water fill valve. it's the rubber piece under the debris screen. if you can get that out and replace it, you'll be golden.
Feb 22, 2009 | Maytag Legacy Series Top Load Washer
Cold water inlet on maytag top load washer not working
switch the hoses fill hoses and if no hot enters you have a defective inlet vavle,,replace...onthejob
Jan 13, 2009 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
243 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
