Question about Fedders A6P09S2A Air Conditioner
A/c won't blow any air
18,000 btu a/c come on but won't blow any air. i can hear motor. Prior to this happening, started hearing a loud roaring noise.
    Sergeant:
    Champion:
  • 214 Answers
Check the status of the blower, if it is not working than try to open the front panel of the ac and check the wiring of the fan......or else contact the service authority. i'm sure that there will be any lose connection or the wire is disconnected/cut..............have a nice day :-)
Posted on May 14, 2009
Error code 61
Check the capacitor in the outdoor unit.
Dec 11, 2013 | LG LSN181HSV LSU181HSV 18,000 BTU 18.2...
Juwt bought a GE 18,000 BTU window unit from Walmart. It runs very loud outside and you can hear knocking noise inside. what can I do to fix this problem?
Did you remove all the packing materials that may have been inside the unit, before installing it? That may be the knocking noise you hear.
Apr 04, 2011 | GE AGW18DH Electronic Room Air Conditioner
Maytag dryer goes on but clothes are not turning
Can you turn the drum by hand? If not there is something Jammed in the blower housing.Do you hear the motor running? Is there Air blowing out the back? If there is air blowing out & you hear the motor it will be the belt. If you do not hear the motor & no air is blowing out then hold the door switch in & turn it by hand as you push the start switch it might start working, If it does it wont last long. If it does not start it is the motor.
Sep 29, 2010 | Maytag Dryers
Doesnt cool room as in prev years
yes the side vents need to be outside the window and if they aren't - the unit will not cool correctly.
Hope this helps.
Jun 08, 2010 | Goldstar WG5000 Air Conditioner
99vw beetle gets really loud past 40mph, like a
Sounds like something is caught up inside or outside the engine/transmission where a part is grinding from something reciprocating. Does the sound happen when you apply the gas without the car moving? If the sound only happens while moving then it could be suspension or transmission related. If it only happens with or without the car moving as long as you control the gas then it's probably in the engine or transmission related. Could also be a wheel bearing issue, that will be a humming sound inside the cabin. As you speed up the pitch increases and the opposite happens when you slow down.
Nov 22, 2009 | 1999 Volkswagen Beetle
98 ford contour 2.5- a loud roar from front drivers side of car
This sounding like an Idler bearing problem, Sounds like the idler bearing that supports your belt is either loose or needs replading. I say this because when you get the RPMs up on the motor the noise should almost disappear?
Aug 19, 2009 | 1998 Ford Contour
Ihave a 1992 caddy deville Ican hear the blower motor blowing .
I may have had a similar problem, for a long time my blower motor made a loud howling/roaring noise, hard to explain, but I only heard the noise when the blower was turned on. It continued to blow air for a couple years then just quit, the noise it made continued for another 6 months to a year without air-flow. Finally it quit blowing air at all. I eventually replaced the blower motor and no more noise and air flow was restored. Hopefully you already have fixed this because removing and replacing the blower motor wasn't fun.
Dec 09, 2008 | 1992 Cadillac DeVille
Problems with my air conditioner
Looks like the main circulation motor is history! Check whether this is the issue. If you find the motor running then its probably the control board that is bad. Also while checking the motor dont get fooled by the motor noise as there is another motor for expelling air out of the room. Let me know what you found so that we can proceed further..
Jun 16, 2008 | Haier Heating & Cooling
Kenmore 18,000 btu Air Conditioner model # 75180 - Condensor Problem
HI , LISTEN MY AIR CONDITIONER DOES NOT START. CORD,THE POWER-TEMP CARD OR WHAT ELSE IT HAPPENED IN A LIGHT OUTIGE. THANKYOU. IT A KENMORE 18,000
Oct 08, 2007 | Kenmore 75180 Wall/Window Air Conditioner
Fedders A6P09S2A Air Conditioner Logo
149 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
