I left the batteries in my baby laser level and they leaked now my level doesnt work is there any one local to the midlands where i can send it to get repaired.
Sometimes you can repair an item yourself. Using sandpaper or a nail file, remove all of the "gunk" from the contacts that the leaking batteries left. You can then wipe the contacts with a little bit of alcohol to clean them up and your level should be a good as new.
If your Craftsman 320.48247 laser level is not working with new batteries, there could be a few different issues causing the problem. Here are a few things you can try to troubleshoot the issue:
Check the battery connections: Make sure the batteries are properly installed and the connections are clean and secure. If the batteries are not making good contact with the terminals, it can cause the laser level to malfunction.
Check the battery type: Make sure you are using the correct type of batteries for your laser level. Using the wrong type of batteries can cause the laser level to malfunction.
Check the laser diode: If the laser diode is damaged or not functioning properly, it can cause the laser level to malfunction. You can check the laser diode by inspecting it for any visible damage or looseness and making sure it is properly aligned.
Check the lens: If the lens is dirty or damaged, it can cause the laser level to malfunction. Clean the lens with a soft, dry cloth and make sure it is not damaged or cracked.
Check for any other visible issues: Inspect the laser level and its components for any visible issues that may be causing the laser level to malfunction. This can include debris or foreign objects that may have gotten stuck in the laser level, or damage to the laser level or its components.
If you have tried these troubleshooting steps and the problem persists, it may be necessary to have the laser level serviced by a professional. A technician will be able to diagnose the problem and determine the necessary repairs.
It sounds to me that you have a defective battery. This can happen if a radio is left on charge or left uncharged for an extended period of time. I could be wrong but this is the most likely cause, especially if the battery is not a lithium one. They have this problem as well from time to time.
If it came from alkaline batteries (Duracells, etc) flush the battery compartment with an acidic cleaner, like an orange cleaner. This will help neutralize the alkaline left behind. Clean that out as best you can. Dont put too much in the battery compartment or it will contaminate the laser internals. Clean the battery contacts, and you should be good to go. if not, then likely the main board has been damaged, and you should get it looked at. They can usually be cleaned up, but it may require a new board.
Try replacing the batteries with a good set of alkalines. The standard batteries that come with these radios are of poor quality and get weak very shortly after purchasing these radios. The radios will have the symptoms you described when the batteries are weak. At least this has been my experience having these radios.
