Question about Epson ACULASER CX11NF All-In-One Printer
Epson CX11nf Dead Fuser?
Been using the Acculaser with great results for 2 years. On color prints, the fuser creates an accordion of the paper and jams. Carefully cleaned the fuser roller but did not fix it. Fuser is $450+ which is 85% of the value of the printer. I don't want to throw it away but buying a new fuser at that cost makes no sense. Any ideas or input are welcome?
Soulvisitor
  • 1113 Answers
SOURCE: HP clj 2550n error 50.2 fuser
Replace fuser assembly is the fix
Normal consumable, the lamp electrics (lamp, thermistor) will have blown.
9337832.jpg Part info
Posted on Jan 13, 2008
Cops
  • 64 Answers
SOURCE: Fuser Error 50.1 Fuser is hot. What is a fuser?
50.1
A low fuser temperature error has occurred, possibly due to an inadequate external or internal power supply.
this basicaly means that either the dc controller board is on its way out (expensive) or that there is a drain on the power line.
if you have it plugged into an extension lead try plugging it directly into the wall socket. if this fails also try using a different power lead (very easy to get hold of and are normaly called kettle leads)
Hope this helps
Cops
Pete@wedotoners.com
Posted on Oct 10, 2007
  • 208 Answers
SOURCE: Paper jam at fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present
Verify that the fuser exit sensor is not stuck
If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest.
Posted on Dec 19, 2007
  • 125 Answers
The fuser bonds the ink powders onto the paper. It is usually located behind the cartridge in the paper path. There may be several reasons why this error shows. (Bad fuser or bad power supply). It looks like this:
http://printerworks.com/Catalogs/hp-supplies/Q3655A-CLJ-3500-3700-supplies.htm
Here is some useful info:
http://www.fixyourownprinter.com/forums/laser/42184
http://www.coldreset.com/modules.php?name=News&file=article&sid=200
Posted on May 12, 2008
  • 9 Answers
SOURCE: Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Posted on Dec 16, 2008
How do I solve this problem? My hp LJ 4345 printer experiences intermittent paper jam in fuser(accordion-like) with half of the paper out of the fuser. We've replaced the fuser with a new one but the
This error can be caused by the following:
1. Fuser that is close to end of life. Maximum print quantity is 225,000 pages.
2. poor quality paper, very thin paper never feeds well and will jam.
3. Printing an image that is almost entirely black can cause the paper to buckle before entering the fuser.
Try different paper to see if that resolves the problem.
Sep 02, 2014 | HP LaserJet 4345mfp Printer
Epson Aculaser CX11NF
hello!
Do you use a required paper substance, this also a cause of paper jump, Or this machine maybe need a general cleaning to all each parts because the sensor that cause to paper jump is not function well. You should properly seat all the parts after cleaning it. and if this not resolve then, to drive an hour to the repair tech maybe is the best solution.
best regards, melnavz
Feb 27, 2008 | Epson ACULASER CX11NF All-In-One Printer
Paper keeps getting stuck in the fuser. Do I need to replace the fuser? I've never replaced it. It's about 3 years old. The paper gets part way in and is folded like an accordion. I've cleared it about...
If it's 3 years old, it might need replacing.
There are two factors. One is that the fuser (hot) rollers get contaminated with toner residue, resulting in them getting sticky. The sheet sticks to the roller, and instead of being fed straight through, it gets bent with the direction of roller rotation, and is pushed under the separator pieces.
The second is that the separator "tongues", that should facilitate separating the sheet from the roller and directing the paper to the output, deteriorate over time. They are plastic, and subject to prolonged heat, so after some time they tend to lose their shape, get cracky etc.
Replacing the fuser is not a hard task, OKI is rather modular in it's construction. The instructions should come with the new fuser unit, and also you can look for directions on OKI website.
Good luck :)
Nov 08, 2009 | OKI C5200n Laser Printer
Fuser rolles up paper, or squaches it... very annoying
plese setup fuser unite prassor properly adjust spring tension
Aug 12, 2009 | Epson ACULASER CX11NF All-In-One Printer
Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Feb 18, 2009 | Epson ACULASER CX11NF All-In-One Printer
When turned on, displays a E537 error code. Solution?
error 537 is a failed fuser. You will need to replace it before you can use the unit. cost of a fuser is about $450 retail.
Gremlin11
Nov 12, 2008 | Epson ACULASER CX11NF All-In-One Printer
CX11NF noise
It sounds as though the noise is coming from you fuser assy. this is the last thing that touches the page before it exits the paper path. The most likely scenario is that the bearings in the fuser are gone and you will need to replace the fuser. the fuser retails for about $450 au.
Gremlin11
Sep 23, 2008 | Epson ACULASER CX11NF All-In-One Printer
Color transparencies are dark & poor color
Nice printer.. Hope this will give hints. Considering transparency papers, please try another batch of or a piece of transparency paper. Try to adjust also the graphics preferences (dark to light) aside from transparency paper selection. Have a nice day.
Best regards,
Rosener Guyano
Feb 17, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF All-In-One Printer Logo
944 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
