Question about GE 21.7 cu. ft. Side-by-Side Refrigerator with Dispenser TFX22ARBWW
I have a leak that seems to cycle once or twice a day. I have made sure the drain at the bottom of the freezer is open and replaced the water intake solenoid. The leak seems to be coming from that area. Help Please!
    Sergeant:
    Champion:
  • 214 Answers
Please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
Posted on May 14, 2009
Water is leaking out drain during cycling; cubes are thinner than normal. Does water valve need to be replaced or check rubber gasket?
Just above the pump there is a check valve that may be stuck open
during operation which will cause thin ice. Also make sure you have the o-ring on the bottom of the drain tube if it was removed during cleaning.
May 20, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Bottom freezer is leaking water. Water seems to
You have a clogged defrost drain. The problem is fixed by unplugging unit from wall, open both doors, blow fan for 24 hours to SAFELY remove the ice covering the drain hole. If you use ANY other method, you may regret it. Once ice is melted, remove debris that is likely blocking the small drain hole, if no debris in drain pan, direct some high pressure air down the drain to block the debris INSIDE the tubing. Furthermore, its a good idea to make the drain hole in the drain pan larger, as sometimes a bubble of water can freeze in the drain hole, and ice could be the cause of your blockage from that bubble.
Jun 28, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
Water in freezer bottom and water leaking out from
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 06, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Water is leaking inside the freezer at the bottom. It pools and freezes. Seems to be once per day. Any ideas
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
Apr 25, 2010 | Frigidaire FRS23KF7AB Side by Side...
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water leaks on the floor. i Is there a tray that
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Nov 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
GE side by side Refr. water leaks under freezer side. seems to be connected to defrost cycle. water can be mopped up with paper towel. put small pan under fridge but does not capture water. Does not leak...
The drain is clogged in the freezer. Take off the back wall inside of the freezer, there is a drain in the bottom, use a turkey baster and hot water to clear all of the ice, pour hot water into the drain, put a piece of weed trimmer line down the hole and try and push the obstruction through, do not use a coat hanger or wire, you will puncture the drain tube and make bigger problems. Finish by pouring more hot water in and making sure it all goes down.
Jun 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Accumulation of water in bottom of fridge
You probably need a new door deal for the freezer. When you cet too much condensation in the freezer, it drains down the back of the refrigerator section during the defrost cycle. Check under the produce bins for a drain. If you don't have one, you're not alone. I used to have have to wipe mine out every other day until I finally replaced the seal.
Feb 02, 2009 | Frigidaire FRT21G4B Top Freezer...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
