Question about Whirlpool Washing Machines
Agitator won't spin
Agitator does not turn during wash cycle....it sounds like the gears are stripped......is this possible? Can it be repaired or do I need a new washer?
    Sergeant:
    Champion:
  • 214 Answers
Please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
Posted on May 14, 2009
SPLINES STRIPPED
Replace this agitator coupling part number WH49X10042 make sure the inside of the agitator is not stripped.
Feb 05, 2014 | GE Profile WPSR3100W
Washing machine operates sporadially
What made you replace the motor? Sounds also like a transmission problem. You motor reversing in spin but gears for agitate stripped in gearbox. Double check motor/coupling alignment. Pull the motor back off and turn the gearbox drive shaft both directions. One direction makes the basket turn, the other direction makes the agitator turn. If the agitator does not move, the gear case is bad.
Feb 17, 2010 | Washing Machines
Spin cycle for tub broken - no spin, sounds like gears stripped.
Hi Ed can you please give model # and make so we can give better advice thanks.
Nov 17, 2009 | Kitchen Ranges
Washing machine is making a clicking/ticking sound when it is agitating during wash cycle
This is a sign of strained agitator components that are about to be damaged or stripped. I recommend pulling the agitator and clutch. inspect each device for stripped components and uneven ware. replace the agitator and clutch if found to be faulty.
Check the transmission(gear box) for damage as well. fill with oil if needed.
May 27, 2009 | Washing Machines
Agitator not spinning hear sounds inside the shaft
Hi, this agitator may have stripped all of the internal gears and plastic drive adapters that allow it to preform its actions during the selected cycles. The only solution here will be to replace the agitator and drive shaft as well. you can order a complete agitator kit with all the parts as well. this will fix this issue. Please rate and god bless:)
Apr 13, 2009 | Washing Machines
AGGITATOR WILL NOT TURN AND WASHING MACHINE WILL NOT SPIN
Hi. you will need to replace the clutch assembly and the drive shaft gears as well. these components allow the agitator to agitate during the wash cycle and if they are stripped or locked, due to a mechanism failure, it will not do its job correctly.
Apr 02, 2009 | General Electric WJRR4170GWW Top Load...
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Knocking sound in agitator
Your Agiator "Dogs" maybe stripped these hold the agiator in the wash cycle place you han on top of the agit. and try to turn it clockwise then go back counter colkwise is it feel like it is grabbing or just free spinning??
Jan 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Agitator not turning during cycle
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
Jul 09, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
